3.0 to 22r/re swap
3.0 to 22r/re swap
This is kind of a strange situation but bare with me. I use to drive an 87 22r 5pd truck, it has a new long block in it and some LCE headers. It is a great running motor/tranny but the frame ended up rotting out, so I bought a 88 truck that has the 3.0/5spd in it with 180,000 miles. The 3.0 engine still runs and I plan to run it until it dies but I really loved the 22r. I dont need the extra power of the v6 and the fuel economy/reliability of the 22r was awesome. So finally my question is what all will need to be done to swap the 22r to a 22re and drop it into the v6 truck. I will be putting the engine/tranny/transfercase all into the truck. I still have the complete running 22r truck, and frame swap is not an option as the 88 is SAS already...thanks for any help I will continue to do lots of research! and if all you have to say is 3.4, its already ruled out because I have the 22r already
you're gonna need all the EFI components from a 22re. That'll get you started. NExt I would assume you just need a wiring diagram to wire it up. Then you'll have to custom make motor mounts, x-member tranny mounts, etc.
PS I totally understand the 22r thing. Toughest engines on earth IMO
The V6 frame mounts are in a different place than the 22R mounts. You cannot just drop the engine in and bolt everything up. Thats why when going from a 4cyl to a 3.4L, you have to A. buy ORS' weld on mount kit or B. fab your own.
I thought I heard something about the 88 v6 runners being different from the others when it comes to the motor mounts. I dont know about this but if I remember right the mounts in the 88 v6 runner are more like the 22re mounts and different from all the others. This was discovered while trying to swap in a 3.4 into an 88 only to find it wouldnt bolt up....
I could be completely wrong I just heard something about it.
discuss
discuss
Good question you have there...I dont have an answer for you but that I can tell you is that a 95' V6 engine fits right into an 88' pick-up. hahah I dont know anything about the 4 bangers mounts but I am fairly sure that anything 90' and down will fit into eachother..
discuss
discuss
This thread is six years old.
I went from 22r to 3.4 and I can tell you that the mounts will have to be cut off, relocated and raised to go from 6 to 4cyl.
The best and easiest way to go is just bolt a 3.4 in and go. Offroad solutions (ORS) or toy only swaps will make a plug and play harness.
Do not forget about different trans and transfer case for a 4cyl.
