Doing front brake bob (Wrong rotors?)
Doing front brake job (Wrong rotors?)
I'm buying all the parts to do a front brake job (new rotors and pads) and wheel bearing repacking.
The rotor I got has six holes but from all the threads I read and FSM. 90-95 rotors have 2 extra holes to bolt into the hub from the back.
I'd like to know so I have all the right parts before I start.
Chris
Chris
Last edited by chris_f; Nov 19, 2007 at 07:14 PM. Reason: Spelling mistake in title.
From what I remember there are 6 bolts in the rear of the hub attaching the rotor. I can't remember if they go through the rotor or not. Should be easy to tell if you take a wheel off.
Thanks that makes me feel better. I was worried because the write up on 4x4 wire the picture has 2 bolts that fastened the rotor to the hub. The FSM for the 93 toyota also stated to torque bolts ..
What year's/models have rotors with two bolts?
So I should be good to go then.. Any pics would be helpful and lastly should I reuse the studs when you replace the rotors?
Solid axle ones I think
[/QUOTE]
[/QUOTE]
I reused mine.
One hint, the bolts holding the rotor to the hub are very tight and probably rusty. When I did mine I found the easiest way to get them out was to put the rotor/hub upside down inside one of my wheels lying flat on the ground. Then stand on the edge of the rotor and the tire, and use a 24" breaker bar to loosen the bolts.
[/QUOTE]
[/QUOTE]
I reused mine.
I meant the 6 that go in the back of the hub holding the rotor on. Mine didn't have the 2 other holes, and it was also a 93
Thanks for the update.
I've got some old locknut's (lost the key) that I've removed with info from another thread on the site.
https://www.yotatech.com/forums/f128...out-key-87469/
It worked like a charm.
If I screw those on and hammer out the studs, shouldn't be a problem right?
Again thanks for the info.
Just thought I'd update and post some pictures (passenger and driver) of my Rotor, pads, oil seal (+ re-greased bearings), brake line and finally the manual hubs change .
Before:
After:
And I thought I'd post a picture to show
1) the way rotor's are attached to the hub. I thought the hub studs held the rotor in place.
2) using the rim as a holder was a awesome, I forget who/were post mentioned that but thanks.
Before:
After:
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
toyoda8488
Jul 5, 2015 10:18 PM
