Rattling sound from the tranny
Old Oct 29, 2007 | 12:05 PM
95toybox's Avatar
When I am driving normal under a load it is ok but when I slow down it has a bad rattling coming from the tranny area. Anyone ever heard this before?
Old Oct 29, 2007 | 12:08 PM
fillsrunner4's Avatar
auto or 5spd
Old Oct 30, 2007 | 07:58 AM
SKNKWRX's Avatar
I get the same thing.....as I let off the throttle slightly at higher speeds there is a buzzing rattle from the drivetrain. This happens in 2WD and I have a V6 Auto 1st gen.
Old Oct 30, 2007 | 06:18 PM
Targetnut's Avatar
My 93 2WD does it too.
I think it is caused by fore and aft play in the transmission. At some point, (hopefully before my trans blows up) I'm going to get a W58 trans to replace it and I'll take my W56 apart to see what is actually the problem
Old Oct 30, 2007 | 06:32 PM
bigredj87's Avatar
Mine is a 22re 5speed 4runner, mine does this same thing when I let off the throttle. It sounds like the whole thing is going to fall apart. It didn't do it before I swapped out my busted transmission for the nice new one. There used to be a nice little bracket holding the exhaust to the bell housing that I neglected to put back. So I think is just the exhaust rattling against the bell housing.
Old Oct 30, 2007 | 06:57 PM
95toybox's Avatar
Mine is a 5 speed. I cant seem to find anything external of the tranny that would be rattling
Old Oct 31, 2007 | 05:25 PM
SKNKWRX's Avatar
Im gonna look there as it really does sound like a buzzy exhaust touching metal noise. I also know my exhaust was replaced entirely so that mightbe gone if you had a pick of where that bracket goes thatd be great! Thanks its been worrying me.
Old Oct 31, 2007 | 06:10 PM
frodin1's Avatar
Is it possible that it may be the heat shield on the cat?
Old Nov 1, 2007 | 04:40 PM
Alex 400's Avatar
mine makes a similar sound but it goes away if i bairly touch the clutch peddle which makes me believe that it is the throwout bearing.
Old Nov 1, 2007 | 07:46 PM
amgraham's Avatar
It's highly possible with the 5 speed that it's failing. Mine started with bearing whine in all but 4th then progressed to an almost heatshield/skid plate rattling sound and the loss of 4th gear. It's amazingly loud (people look at me from the sidewalks and when I'm on the phone people on the other end ask me what's going on in the background). I'll be swapping it out Sat so I'll post up if I find anything else that might cause it.
Old Nov 1, 2007 | 08:27 PM
T4R 4ME's Avatar
While we're talking about tranny sounds, does anyone get a humming vibration @ 30mph? I've been noticing this from somewhere towards the front of the center console, but can't pinpoint exactly where. Doesn't matter is I'm accelerating or decelerating as soon as I hit 30phh it does it. Its an auto.
Thanks!
Old Nov 10, 2007 | 06:03 PM
95toybox's Avatar
I hope it isnt the throwout bearing. I checked my exhaust and it isnt coming from anyone on that
Old Nov 21, 2007 | 09:21 AM
95toybox's Avatar
Ok well I was wrong Come to find out it was only a bolt on the cat that was loose and made a very loud rattling noise. Luckily the throwout bearing is good for now
Old Nov 21, 2007 | 06:44 PM
bigt's Avatar
my 93 4runner also has the sound that if you touch the gas or the clutch it goes away.. sounds like its coming from either the clutch or the rear gears... has been this way for a year... cant be that bad hahaha i hope. i have a whole 22re plus 5 speed in my parts truck
JNapolitano
Nov 14, 2019 07:46 PM
donovanloj
Aug 16, 2015 10:07 AM
norcal98
Aug 10, 2015 06:20 AM
ahriman
Aug 1, 2015 10:38 AM
Iceman4193
Jul 15, 2015 04:48 PM
