weird noise
Old Oct 20, 2007 | 01:58 PM
yota_dude's Avatar
weird noise
i have an 88 pickup with the 22re but when i get the motor to about 3000 to 3500 rps it sounds like the fan is hitting something. there is no check engine light and as soon as i get above that point it is fine again. i checked the oil fan and there is no damge.
Old Oct 20, 2007 | 02:08 PM
thook's Avatar
Oil fan? Do you mean the cooling fan?
Old Oct 20, 2007 | 02:24 PM
yotasavg's Avatar
maybe i should invest in an oil fan too!!!
Old Oct 20, 2007 | 02:36 PM
TORTIS's Avatar
i am a dooms day persons, so i say timing chain. did they sell you some muffler bearings to go with the oil fan.
Old Oct 20, 2007 | 07:54 PM
yota_dude's Avatar
i replaced the timing chain less then 10k ago should my fan wobble at all when i rev up the motor it moves maybe 1\2 an inch.
Old Oct 20, 2007 | 07:58 PM
BluYot's Avatar
My waterpump was apparently loose when I first got my truck. Turned out to be hitting the fan when it came on. Just a thought.
Old Oct 20, 2007 | 08:07 PM
yota_dude's Avatar
i will look in the morning when the sun desides to come back up
Old Oct 21, 2007 | 08:13 PM
84sr5yoty's Avatar
If your fan is hitting the fan shroud under hard acceleration then you need to replace you motor mounts.
Old Oct 21, 2007 | 08:52 PM
the_4runnin'_beast's Avatar
I only got a kanooter valve with mine... i knew i should have held out for the muffler bearings... or at least a free bottle of headlight fluid.
Old Oct 23, 2007 | 09:23 AM
yota_dude's Avatar
it has somthing to do with the power steering pump bracket cause if i put a pry bar between that and the header and pull a little bit it will stop. in the power steering bracket how many bolts hold it to the block?
Old Oct 24, 2007 | 04:59 PM
n4ynu1010's Avatar
Motor Noise
Not really , is the play in the fan clutch and if it is driven with the water pump is the play in the pump/pulley ?
And previous post is right as well , if your motors mounts are broken or heavily worn it could be that as well
Old Oct 25, 2007 | 09:17 AM
ssupercoolss's Avatar
Are you low on horn oil too? sorry had to do it. look at your fan shroud, if the fan is hitting it at some point, there will be some evidence there..
Old Oct 25, 2007 | 09:49 AM
n4ynu1010's Avatar
LOL , Horn Oil
Old Oct 26, 2007 | 09:38 PM
just a 22re's Avatar
wow you guys are really mean he has a real problem and from being really tired just like me messed up on one word just like me and everyone gets on him for it dude i hate to say it but i had the same but mine was a lower end knock and a very lose chain take the valve cover off and see how play is in the chain mine had about 2 to almost 3 inches of play then it locked up woo whoo new motor with a heavy cam coming soon!!
Old Oct 27, 2007 | 06:47 AM
n4ynu1010's Avatar
Clutch Fan Wobble
Did you find the problem man ?
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
