Brake lights stick
Brake lights stick
every time i press the brake the lights stick on, i have to tap the pedal once or twice to get it to go off. im afraid its gonna drain my brand new battery, what should i do correct this problem.
Brake Light Problem
Switch may be bad ( about to commit electro-mechanical suicide) , may need some lubricant (lubricating Momentary Switches is good for switch if you use the proper lubricant ), or switch may be loose (mounting hardware) , heck could be just a wire has fallen in the way keeping pedal arm from depressing switch or wire harness plug may be loose , probably a simple problem
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
