2nd Gen Power Antenna
if the motor is still good the mast it self is only like 14 bucks at the dealership. then put a switch on it so that it only is up when you want it. and down when your wheelin
oh thats going to be more $$ but call around junk yards or pull-a-part
I just have a stationary one, which is loose. I want to replace it with a power one, if thats possible, so when I'm wheelin in the woods I can just put it down.
power antenna swap in
you might need to get a power antenna relay too. there's a plug for it under the dash near the steering column.
-socal
-socal
Thanks for the info, I'll need the relay too. What do you mean by "plug under the dash near the steering column," there should be a spot to plug a relay in?
power antenna relay
yes - there should be an electrical connector somewhere under your dash that the relay plugs into
-socal
-socal
Ditch the POS electrical one and go with a fixed mast. There are part #'s under a write up in the tech section. I went through 3 power ones before I wised up.
I have a fixed mast antenna currently. The thing is, it's loose and I figured it would be better to have one I could put up or down when I needed.
Still looking, if anyone has the antenna parts let me know. I also need a 2nd Gen 4Runner tailgate, has to be rust free, and preferably black in color.
Thanks,
Chris
I wish it worked that way for me, anytime my radio or cd player was on the antenna was up, didn't know i could have bought a switch to make it stay down. I ended up breaking mine on a tree branch. I want to switch to a fixed one.
Jun 1, 2021 01:51 PM
Steezy96yota
Jul 6, 2015 10:00 AM
