FPR Vacuum line?
Old Sep 26, 2007 | 06:44 PM
Garrett's Avatar
FPR Vacuum line?
hello I need help identifying a part. I have a 96 3.4 V6 and on the vacuum line to the FPR or the line that comes off the Intake silencer in the upper right this line leads to a relay or some magical electric thing with this vacuum line attached to one side and another leaving the other. What is this thing? and what does it do? The vacuum line attachment is broken on mine and I need to replace it. I have been searching for this and don't even see the part on others engine photos. Thanks Garrett
Old Sep 26, 2007 | 06:59 PM
4Crawler's Avatar
If it is anything like on the earlier engines, see the web page below:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/8.html
The fuel pressure regulator is modulated by the engine vacuum, high vacuum = low engine load = low fuel pressure, low vacuum = high engine load = high fuel pressure = more fuel flow. The vacuum switching valve is supposed to eliminate some sort of hot start problem by boosting fuel pressure during hot starts to prevent gas from vaporizing. I removed my VSV many years ago and have observed no starting problems, hot, cold or otherwise.
Old Sep 27, 2007 | 06:07 AM
Garrett's Avatar
Thanks I think thats probably what it is. I suppose when I remove it I just connect the vacuum line and leave the plug hanging?
Old Sep 27, 2007 | 06:14 AM
4Crawler's Avatar
That is what I did on my '85. Some day I might hook up an indicator light to that unused plug just to see when/if it comes on. At least in the early EFI engines, this was only a "feature" on the 4x4 vehicles, on the 2WDs, there was just a direct vacuum line from the intake to the FPR.
More info:
raptor510
Aug 19, 2015 02:15 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
