2wd rear - too stiff
Old Sep 23, 2007 | 01:38 PM
Travisfab's Avatar
94 reg cab 2wd
The rear end is just way too stiff for me. Has anyone took out the overload leaf? I was thinking about doing that and maybe adding a regular arched add-a-leaf spring. Any input or ideas?
Old Sep 23, 2007 | 03:52 PM
jcfb's Avatar
Well, you don't want to bottom out. Hmm... I know a lot of the 4x4 guys are modifying the spring mounts and running Chevy 63" springs. A longer spring will translate to more flex/easier flex. I assume this would solve your stiff problem. Check out the Chevy spring on Toyotas FAQ over at Pirate to see if you might want to tackle something like this.
Specifically this statement in the FAQ:
How much lift do these springs give?
You will get about 2-3" of lift. But the springs are very soft, so most people end up using some lift blocks?or add-a-leafs as well.
http://www.pirate4x4.com/forum/showt...threadid=20665
Old Sep 23, 2007 | 04:04 PM
4Crawler's Avatar
Originally Posted by Travisfab
94 reg cab 2wd
Likely is stiff because the rest of the (softer) leaves have sagged to the point of riding on the (stiff) overload leaf. Remove the overload and that may be too much for the rest of the leaves. You might try something like the Rancho Soft-Ride Add-a-leaf kit, it includes a pair of AALs, one long/thin, one shorter/stiffer and try those.
Was on one trip with a guy who just got a 4WD Toyota pickup. He had found the rear springs were too stiff and too out the overload. He had a very soft, flexy ride. But at the first steep climb on the trail were were on, his rear axle hopped once (axle wrap) and he now has "S" shaped springs, axle riding on the bumpstops and those springs were toast. The overload does help protect the rest of the springs from overloads, both in direct vertical loads, but also in terms of excessive torque to the axle.
Old Sep 30, 2007 | 01:16 PM
Travisfab's Avatar
So...
I took out the overload leafs and put in an add-a-leaf. The add-a-leafs I used were originally in a Ford Ranger (spring over). I put them right in the place of the overloads. The ride is a lot nicer and I got about 4 inches of lift. I definitely have more travel now and will need to get some longer shocks. Anyone considering a lift shackle, should definitely do this instead.
Old Nov 30, 2007 | 07:31 AM
Travisfab's Avatar
Just a little update on this. The ranger add-a-leafs worked great, but it had my truck sitting ass high. If my front end was lifted more around 6 inches, it would have been perfect. So what I did was cut 6 inches off either side of the add-a-leaf, so that it had less arch. Re-installed and I am sitting with about 2 inches of lift over stock, which is perfect for my application. I definitely need longer shocks now, my shocks top out before I get all of the droop travel my truck is capable of.
Old Nov 30, 2007 | 07:41 AM
4Crawler's Avatar
Yes, adding an add-a-leaf can help improve the ride, at least if the ride was stiff due to the old springs sagging onto the overload leaf. Since the AAL can flex more than the super stiff overload leaf, you now have a spring pack that can flex.
Old Nov 30, 2007 | 08:26 AM
Travisfab's Avatar
Exactly,
I tried it out for about a week without the overload or add-a-leaf and I was bouncing off the bump stops all the time. I like to do suspension modifications that actually do something. A shackle, or lift spindle for example, do nothing to improve your suspension.
andrewtexas123
Jul 23, 2015 11:22 AM
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 16, 2015 11:32 AM
icentropy
Jul 14, 2015 10:23 AM
hexrain
Jul 12, 2015 01:13 PM
