Done HG replacement - clutch pedal is now dead??
Old Sep 19, 2007 | 06:13 PM
snelson's Avatar
92,V6 3VZE 4x4
Hey guys,
Well, I have everything back together after removing heads to have sparkplug threads fixed. But just noticed that my clutch pedal is now dead? Goes straight to the floor. What have I done? Will it regain 'pressure' once the truck is started??? Everything is definitely all connected, there was no fluid leaking anywhere....
I haven't started the truck yet - I'm one of those guys who decided to peak inside the MAF by unscrewing those two little screws!
So - waiting to try and get a deal on a used MAF before starting it up.
Thanks for any hints re. the clutch pedal.
Old Sep 19, 2007 | 06:25 PM
corvey's Avatar
Well, my 4runner is AUTO, my Mustang 5.0 is a "manual" 5 speed so there is no fluid, but my Kawasaki ZX9 has a hydraulic clutch. I don't know if the 4runners have hydraulic clutches or not, but if they do, you may have knocked the line loose it will need to bled it to fix it.
Old Sep 19, 2007 | 06:28 PM
Tylerars24's Avatar
start by bleeding it
Old Sep 19, 2007 | 06:30 PM
881stGenRunner's Avatar
X2...
Old Sep 19, 2007 | 08:00 PM
89macrunner's Avatar
probably just needs some fluid..the clutch master cyl. is right by the brake master cyl.
Old Sep 20, 2007 | 07:15 AM
eric-the-red's Avatar
Did you have to disconnect the flexible clutch hose near the back of the passenger side head, if so you lost some fluid and let air into the hydraulic system. Like the other guys said bleed the clutch, just like bleeding brakes only simpler cause there's just one.
Old Sep 20, 2007 | 07:00 PM
snelson's Avatar
OMG - I'm looking at the FSM on how to bleed the clutch - but I can't determine where the heck this thing is located? Is the bleeder nut/plug right under the reservoir??
Anyone got a pic handy for a dim-whit?
EDIT - Ahhh found a great post with detailed instructions
https://www.yotatech.com/forums/f2/b...ylinder-15519/
Old Sep 21, 2007 | 07:49 AM
black diamond's Avatar
the bleeder is on the slave cylinder, which is under the truck, it pushes the shift fork in and out, which is on the bell housing of trans, near starter.
Old Sep 30, 2007 | 08:01 PM
snelson's Avatar
Just a quick thanks for the suggestions - you guys were right (as usual), all I needed to do was bleed the system, all back to normal now.
Thanks again
Old Sep 30, 2007 | 08:13 PM
corvey's Avatar
Right on bro! have fun shifting
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
