22r carb issues
1982 4x4 22r carb issues.
I have had this truck for about a 2 years now and it has never run quite right. It would always warm up just fine and as soon as it came off cold start cam it would die. I could always keep it running with two feet so never thought much about it. E-test comming up next mounth so needed to fix it. I did EVERYTHING everyone said to do under the hood. Plugs, cap, rotor, wires, carb rebuild, PCV, filters, etc, etc, etc,...... The idle cut solinoid checked good as did the vacuume switch per all the manuals I could find. Turn out to be the ground wire (Black) in the harness for the idle cut solinoid. Ran a jumper ground wire from solinoid to vacuume switch and truck runs great !!!!!! Idles great. So if you are having idle problems check this area. It drove me nuts for two years.
