Sponsored by: CARiD
22r carb issues
Old Sep 11, 2007 | 09:56 AM
WSUWESTON's Avatar
22r carb issues
Ok, so I rebuilt my carb off my 82 toyota 22r and now I can get the truck to run, but it dies when my foot is off the gas. What should I try adjusting?
Thanks
Old Sep 11, 2007 | 10:09 AM
TACO626's Avatar
Sounds like a vacuum leak
Old Sep 11, 2007 | 11:35 AM
WSUWESTON's Avatar
I am sure I hooked all the lines up corectly. I numbered them and took pictures. Then I cross checked with my manual. Any more help?
Old Sep 11, 2007 | 11:40 AM
TACO626's Avatar
Carb base gasket in good condition?
Old Sep 11, 2007 | 11:45 AM
WSUWESTON's Avatar
It's new and looked fine when i put it in??
Old Sep 12, 2007 | 03:03 PM
surf4runner's Avatar
adjust the idle?
Old Jun 11, 2008 | 10:05 AM
DANIEL REED's Avatar
1982 4x4 22r carb issues.
I have had this truck for about a 2 years now and it has never run quite right. It would always warm up just fine and as soon as it came off cold start cam it would die. I could always keep it running with two feet so never thought much about it. E-test comming up next mounth so needed to fix it. I did EVERYTHING everyone said to do under the hood. Plugs, cap, rotor, wires, carb rebuild, PCV, filters, etc, etc, etc,...... The idle cut solinoid checked good as did the vacuume switch per all the manuals I could find. Turn out to be the ground wire (Black) in the harness for the idle cut solinoid. Ran a jumper ground wire from solinoid to vacuume switch and truck runs great !!!!!! Idles great. So if you are having idle problems check this area. It drove me nuts for two years.
dumpster84
Apr 30, 2016 06:03 AM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
