Help please! Transmission leaking!
Hi. I recently changed my clutch about the beginning of summer.
I got under my truck today and noticed that i am leaking transmission fluid from the rear of my transfer case. Right where the rear drive line hooks up to it.
I am wondering if there is a seal there that i may have destroyed during disassembly or reassembly. The only other thing that i can think of is that i put to much gear oil in there and its spitting it out the only way it can. If i remember right i put in about 3 quarts. The amount listed in an 86 factory repair manual.
Any advice or tips are greatly appreciated!!!
Thank you!
-matt
Thank you!
-matt
did you drop the transfer case? the seal may be wore out. if i remember right. pull flange and the seal is right behind the flange. are you sure it is not coming from the transfer case shifter?
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
yourrealdad
Jul 29, 2015 11:08 AM
HookahRoo
Jul 20, 2015 07:06 PM
