Pinion Nut
On a 1987 toyota front pinion can the nut be take off with out hurting the pinion, and what about the nut, you will need a new one I assume, where is the best place to get one? I am replacing the front seal.
Thanks
Thanks
Get the new nut from the dealer.
The only problem might be retorqueing the nut and maintaining the proper adjustment of the pinion to ring gear clearance. The crush sleeves are intended to be used only once.
If I put a solid sleeve backin that should take care of that issue. Does the transfer case have a crush sleeve also??
I think that the solid spacer kit from Yukon Gear comes with the shims. Solid spacers are the way to go. Much easier to deal with than messing with the crush sleeves.
btw: I made a mistake earlier. The crush sleeve sets the bearing preload on the pinion gear rather than the pinion clearance which is set separately.
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
