grill painting
grill painting
ok so my grill is pretty worn, along with the plastic molding around the front lights, so im gonna paint em up in preparation for selling the truck...gotta make it look good
so my three choices
1-black
2-stainless steel, looks like gray, but metallic
3-keep it fake chrome look
so far im leaning toward black, i think that will make it look the best...
and yes i will do the small trim eventually around the outside of the side blinkers...
so my three choices
1-black
I did mine black.
Make sure you scuff up the chrome really good, or the paint will not hold up. I used a palm sander and wire wheel, two coats of primer to fill in small stuff and then two or three coats of black.
Side markers i just taped em off and did the same thing.
whatever you do, take your time. sand/scratch the plastichrome and take your time with the paint. say, full coverage by the 3rd coat
on a red truck, i'd personally go with a light silver or dark gray. the black would look good, but it might make it look cheap.
I did mine black.
did you use plastic paint or just rust oleum? i havent yet decided what i wanna do...
i hear ya, im pretty darn good with prep/paint work tho so im not too worried, im more worried about what color i should paint it...i can picture both in my head, but i dont know what would look better...
here is what i would do... i would scuff up the chrome really good with some 400 on a DA and hand sand the rest.. then for that semi gloss look i would buy some ppg DP 90 epoxy sealer and spray it with that ( this stuff bites into chrome very well, but its expensive) if you want something cheaper, scuff the chrome with 400.... get some etch primer put a few coats of that on it, lightly sand again with 400... spot prime the spots that come through.. then spray with whatever semi black you want, I'd go with a SEM product or whatever auto trim paint suits you.
OH and the cleaner just get some mineral spirits and use this procedure.
good luck post pics
good luck post pics
sorry, i found the article, it was about the paint prep; using slower activators and reducers than ordinary paint. the wash is soap and water only; no wax & for a grille that should be no problem...sorry about the mistake.
Krylon Fusion spray paint for plastic in any color you want at Wally World
Sand the chrome off
Windex
Wipe down with lint free cloth
Spray paint a coat
Dries in 15 minutes then add more coats as desired
Here is mine
Sand the chrome off
Windex
Spray paint a coat
Here is mine
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
bryan34w
12
Sep 30, 2015 02:50 PM
Toys4parts
Sep 26, 2015 01:56 PM
