Cleaning my Motor
Wait until the engine is cool and then put plastic over any electronics. I usually wrap the distributer and alternator. Then I spray engine gunk or some kind of cleaner on the engine, scrub it a bit, and then rinse well followed by starting the engine and letting it run for 5 minutes.
Key is not to use a pressure washer and don't flood any electronics. Basically use as little water as possible.
Anyway, others might have different opinions but this is what I do and it hasn't broken anything yet.
I like to use simple green for grease and car soap for any mud....does a pretty good job. Just make sure your motor is cool, and try not to spray the alternator, battery, fuse box etc...They don't mix well with water lol
All my electric shizzile is greased up and i have some sealant in the connectors to keep them dry, it works awesome, for cheap use oven cleaner ONLY ON THE BLOCK it will take off paint and eat anything else. I love it we do it to all of our vehicles(the sealing) and it helps. Then i take my pressure washer to everything even the battery. If you put grease on the terminal posts, slide the terminal on, tighten slightly, then put a socket that wont interfer with the post and hammer it on, then tighten till satisfied. it will keep them nice and tight
Don't use anything you don't want to smell for a while!!!! Simple green is pretty light on odor and does a decent job. I have always wondered about about steam cleaning, I have never been satisfied with any method I have used. I think that is what dealerships do before reselling a vehicle.
some good ideas, ill have a go at it today. in past attempts it has run very rough upon start up. i did use a pressure washer, that was the only way to get all the built up mud off. i have some simple green and degreaser that ill try.
now, go scrounge up some plastic bags and start covering the sparky stuff.
lee
lee
hehe, mine came up looking pretty good, all things considered. there is still some caked/burned on mud that just wont budge, oh well. did some other light maintenance while i was in there.
checked all the plug connections on the cap and used some dielectric grease on the posts. cleaned up some of the other connections and did the same treatment. next weekend, pull the air box to get at the plugs and get the other ends done as well.
lee
lee
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
