Opinions on 3vze HG Job/Parts list
Okay, so I've decided to have a shop do my new HG for 1st time after recall. Truck has 127K. I'll supply the parts and he will install for $1000. Plus he will give me a 1 yr gaurantee. Head work extra $440+/- from local machine shop (incl. press. test/shave heads, grind valves, install new valve seals, shim/adjust valves) depending what I need. Using all toyota parts except for Topline head bolts. New parts: Valve grind gasket set, timing belt, knock sensor & wire, water pump, radiator + hoses, all belts, O2 sensor, coolant temp. sensor, thermostat, plugs, wires. Parts: $800 +/-. Only other adds might be exhaust system and injector svc. Any thoughts on something I missed would be appreciated. Thanks.
not sure I could do a 3.4 in my area for that..plus the mods required..I would need about $400-$500 in tools alone to do the work above myself...could save about $150 if I went with enginbldr for the gasket set though instead of the oem. Not sure if engnbldrs set includes all gaskets from block up?
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
