Wheel Back spacing questions
Old Apr 15, 2007 | 11:13 AM
Sosborne's Avatar
I am getting ready to order a set of Rock crawler steel rims and I am not sure about the backspacing. I have a 94' 4runner with 31x10.5s I have only about 1.5 inches of lift. Should I go with the 3.75 spacing or the 4.5? Also the bolt pattern is 6x5.5 correct?
Thanks
Scott
Old Apr 15, 2007 | 11:16 AM
TNRabbit's Avatar
3.75 is the correct backspacing. You can run those tires on stock rims (15x6), and were, I believe, standard equipment on the SR5 models.
Old Apr 15, 2007 | 11:20 AM
Sosborne's Avatar
Yep i think they were. I am planning on getting the 15x8s just incase I go to 33x12s on the next tire change.
Any problems with 31x10.5 BFG TA/KOs on 15x8s?
Thanks
Scott
Old Apr 15, 2007 | 11:22 AM
TNRabbit's Avatar
Nope.
EDIT: now that I think about it, you might need to adjust backspacing for a wider WHEEL...anyone know for sure?
Old Apr 15, 2007 | 11:41 AM
dijlop's Avatar
am i going to be looking at any back spacing issue's or anything with 29 bfg at's on 14inch rims on a stock 94 2wd pu? if need be i can lift it about an inch all around, but not much more. thanks
Old Apr 15, 2007 | 11:50 AM
bruzer's Avatar
Originally Posted by TNRabbit
Nope.
3.75" back spacing should work fine up to a 12.50. I am running 33x12.50's on a 15x10 steelie with a 4" backspacing with no issue's.
Old Apr 15, 2007 | 11:58 AM
waskillywabbit's Avatar
I run 3.75" backspacing...15x8 rim with DIY beadlocks and a 13.50 wide IRok.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
elwood73
Jul 5, 2015 07:07 AM
