2nd Gen 4Runner Rear Upper Shock Brackets
A few months ago MarcP had mentioned he found some brackets from a Jeep lift that would convert the upper shock mounting hardware from a "pin" mount to an "eye" mount. I think a few people here have fabbed some up something similar themselves. I was browsing the net and found these pre-fabbed and independent from a lift kit. They are made by Rubicon Express and can be found HERE.
They require that the diameter of the mounting hole be increased by about a millimeter, other than that they bolt right on with a 27mm socket. Now I have a heck of a lot more shock options.
The brackets
Mounted some Bilstien 5150's
The brackets
That is an excellent idea. I learned first hand the other day about just how fun it is getting to that upper shock bolt on the passenger side. My only question/concern would be the limiting of travel. is this a factor?
FYI - a Flex Head Angled 3/8" ratchet with a 14mm deep well will fit between the frame rail and the body for those upper shock mounts. Of course, if you have a body lift, you have no issues getting to it. Sorry for the basic info.
Kat
Kat
Team420
Jan 12, 2021 04:57 PM
infinityisfive
Jun 16, 2015 06:51 PM
