timing chain cover gaskets
just starting to get my timing chain istallation back together here, and 2 quick questions.
are we using some silicone (rtv) on the gaskets?
one write up on the timing chain use some tape on the tensioner. is that to compress it? then when all said and done, pull the tape to let it go up against the chain?
thanks
thanks
use permatex on the paper gaskets, you are also right w/ the tape, but you can also just compress the tensioner w/ your fingers
if you haven't already save yourself the agony and buy replacement timing chain guides....when you torque the crankshaft bolt do not try to keep it from turning by lodging a screwdriver in the camshaft sprocket (the force is enought to break the camshaft sprocket) if you have a manual tranny you can put it in 5th gear and the engine won't turn.
i'm not sure what write up you are using but this is a good one http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
