1987 EFI Toyota Truck
My partner just got a truck for FREE, Thats right free. It is a 1987 EFI Toyota pickup truck with a 22re engine. The truck starts up fine, but runs very ruff ynuless he keep his foot on the gass. After warming up, it purrs like a kitten. Any idears.
Also, he would like to no what type brand of spark plus to get for this rig as well as an oil filter, and the type of oil you all think would be best. The rig has 200K on it now. Other then that, the truck runs fine and has plenty of power. Just at startup is the only problem.
Any help would be great.
Also, what does EFI stand for. It is the lettering on the door ? Thanks again.
I will post pics ASAP.
It's EFI. Electronic fuel injection. Meaning not carbureted. It was a big deal in the late 80's, so makers put the abbreviation on the outside of cars lol.
As far as the rough starting, it could be your cold start injector. Check out this thread for more info: https://www.yotatech.com/forums/f116/early-22re-hard-start-101537/
Rob
Rob
Can anyone help on telling me where to look for this plug, or what it looks like, and is it hard to install. Also what does it cost. Thanks.
have your partner pick up a haynes or chiltons manual, it should have plenty of tune up information in there, spark plug gag, type of oil & filter, trans fluid, gear oil etc.
a good way to learn about basic maintenance and could save you some $$$ by doing some work on your own.
lee
lee
Cold start injector and cold start injector time switch is for cranking the motor over only and have NOTHING to do with a rough cold idle. The air valve is the device that increases the idle during warm up on a cold motor. Usually the air valve orfice(s) get plugged up and the motor chugs at a low RPM until warm. I believe in 87 they incorporated the air valve into the throttle body vs. an externaly mounted one which were on 84 & 85 EFI models. Search for "air valve" in the search engine and you'll find picture.
Rob
91toybeater
Dec 27, 2015 07:46 PM
