92 4run questions
Old Feb 11, 2007 | 11:31 PM
toytruckbmerbike's Avatar
92 4run questions
Hey man I am stuck My toy will start but once I step on the gas to start off not hard just normal, The engine light comes on? TPS sensor? the truck runs fine for the first 1/2 hr then it will stall or stumble "loop" if you will even while driving. the truck is retarted on gas I mean 30$ @ 98.6/litre gives me about 150km and I'm lucky if I get that I put new Plugs Bosh4, Wires, cap, button, K&N filter checked the rubber intake hose and collector boxes for holes, none. Seems to have even compression, The map sensor checks out any ids guys I am stuck
Old Feb 11, 2007 | 11:34 PM
just a comment the air bags for the coil springs in the back of these bad boys are a wicked and easy mod for towing and body roll while driving
Old Feb 11, 2007 | 11:37 PM
Elton's Avatar
o god bosch plugs get those out of ther asap
Old Feb 12, 2007 | 04:55 PM
Just Learning's Avatar
i think this pic speaks for itself
Old Feb 12, 2007 | 05:01 PM
chrishf12's Avatar
does the check engine light stay on?
itsmeagain5789's Avatar
o yea, only put ngk or denso in there
Old Feb 12, 2007 | 05:03 PM
littlerunner's Avatar
i 2nd the bosch plugs.they are junk in a japanese anything.get em out now!!!
Old Feb 12, 2007 | 05:05 PM
Old Feb 24, 2007 | 11:13 AM
thank you guys I will try it and get back to you
Old Mar 7, 2007 | 05:12 PM
i've come to find out it is the knock sensor (code 52). when I traced the wire, I found it was cracked and corroded just below the intake, where it comes out of the block (between the connection and block). Any suggestions on how to fix this?
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
