clutch acted real weird now slipping?
I have a 1995 4 runner 3.0 5 speed 4x4.....
I was out driving and went to shift from 3-4 and depressed the clutch and the tranny shifted out of 3rd fine but would not engage 4th or any other gear. got the truck home b/c of the clutch cancel switch. I could put it in gear with the truck off so i new the tranny seemed fine. when i got home i pulled it into the garage and heard a pop from under the truck not sure what it was. At this point the clutch pedal was working and while the truck was running i could put it in gear. So I went to move the truck and the clutch is slipping real bad.
I need some input before i pay 200 for a new clutch and pull everything apart
It almost seems like the pressure plate let go....
per the previous owner the truck is supposed to have a centerforce dual friction clutch in it also per the previous owner should have about 45k miles on the clock
If anyone can shed some light i would greatly appreciate it i did a lot of searching but my situation seems real unique.
thanks alot
thanks alot
Not sure on a 3.0 standard trans., but on the 22re standard I have you can look in the bellhousing via pulling off the boot for the clutch fork. Might give a look at the throwout bearing and the retainer clips. Not sure, it's just a thought.
he's gone
7
Dec 3, 2019 07:08 AM
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
