water pump weep hole?
on an 94 pickup 22r-e anyone know if the water pump has a weep hole and where its located?
Thinking I might need a pump. Getting a lot of dark built up dirt below water pump.
weep hole?
Theres only one hole on that water pump and thats where the shaft comes out that mounts to the fan.
It's not uncommon for the seal around the pump to go to but usually the shaft seal wears out.
Water pumps are only $25-$30 or so at a parst store.... then cost of fluids. Easy fix imo (done a few)
can this weep hole be visually seen from outside the pump?
looking from underneath the truck?
Whats a good pump to get? aftermarket or dealor?
hey drew303, clean truck man!
