What other seats work as a replacement?
I want to replace the bench seat in my '87 with buckets. Be great to find a good pair of 4runner bolt ins, but you only end up finding seats more worn than my bench!
Those aftermarket seats are freakn expensive!
I have a set of 90 Integra seats I'm about to put in mine. They are similar dimensions but I'm gonna have to make brackets for them (I don't want to drill any more holes so if I find a nicer set of seats I can still swap them out).
I put in Prelude seats. the fronts bolted in fine, the rear set needed spacers and a hole drilled. Took me about an hour to bugger weld (don't have a proper power set up in the garage yet) a couple brackets on and run to Napa to get a couple longer bolts to bolt them in.
Got he seats at the pick n pull for about 35$
im lookin for some buckets to replace my bench seat, im not a big fan at all, i dont even care if they are the same color, im gonna put covers on anyway. 91 pickup if anyone has any ideas, sorry for the thread jackage, but it went along with the topic.
-=Morphine=-
1st gen seat options
Here are the 89 prelude seats I put in. I chose to make new front mounts and a rear mount (Z shaped-you can barely make it out in the pic) The fourth hole by the center console was just as Reggie said, new hole and a spacer.
Be warned if you haven't worked with metal before I don't recommend making new brackets. If you do, use as heavy a gauge steel as you can and shake the truck by holding the seats when you are done. (completely unscientific, I know-you may get some small amount of movement at the sliders depending on the age and quality of the seat anyway)
Also, please use the highest grade bolts when attaching any fabricated parts to the seat rail. Remember, the seats and seat belt are the only thing holding you in!
Don't cut corners on this install, it's your life you're playing with if you do!
i got a good one for you all i have a set of seats from my old 1990 mitsu eclipse gsx that i welded in but a set of any honda from 88 to 92 i think just bolt right in with only the part of having to drill holes for the back bolts cause thats what was in my truck when i got it
I have a set of Recaro's in my 87 pickup from a 2nd gen jdm Hilux Surf, they bolted right in. They're awesome seats, a lot firmer and I sit up a little higher. I also had a 1st gen. runner with 3rd runner seats, but the brackets had to be changed modded to fit.
I've got an 88 standard cab and just recently replaced the bench seat with buckets from a 2002 Honda Civic. Had to enlarge the bolt holes on the seat brackets a little but three of the four holes then lined up with the stock locations. Only had to drill one hole in the back for each seat. I then had enough room to put in a small center console from a Jeep. Check Ebay if you don't have a local source for seats. Got both of the Civic seats in really good condition for $50. Console was $25.
That's an awesome install. I'm hitting the salvage yards tomorrow for some prelude seats. Thanks for the insipiration.
Thread resurrection.
My driver's seat won't stay in the full upright position and that's how I drive, plus both seats are really worn out. I like those prelude seats.
Anybody do anything else?
Anybody have mastercraft seats their yotas?
I want to replace mine, but I want to stay with a bench as I got a 4 year old and a girlfriend and don't want to use the 3rd seat. The support bar that runs from one side to the other behind the seat is a kidney killer. Stupid thing is I like the look of the factory seats. Looks like buckets from the outside.
voiddweller
19
May 2, 2016 09:10 PM
infinityisfive
Jun 16, 2015 06:51 PM
