1984 High beams stuck on...no lows
Old Dec 19, 2006 | 09:42 PM
SLC97SR5's Avatar
My truck's high beams will not cycle back to low beams.
I removed the columm and steering wheel to get at the combo switch, it actually looked pretty good but I filed the contacts and hit it with some contact cleaner anyway. (per 4crawler.com, thanks RB!)
The high beam relay is working, if I remove it with the lights on they turn off completly.
If I get the combo switch in just the right position the lights will go out and then immediatly switch back to high beams.
What can I do to get full functionality or at least disable the high beams and only use the low's. I thought about simply re-aiming them down so I don't blind folks.
I called the dealer and they want 223.00 for a special order switch!!
Old Dec 19, 2006 | 10:05 PM
DeathCougar's Avatar
so get one used?!!
We offer them up (whole complete assy ready to install) for much less than $223!!
btw....what they sell you is the light switch side only, and you have to de-pin the wiring and re-pin the new switch in. Its a real pain the the butt!!
Old Dec 19, 2006 | 10:10 PM
SLC97SR5's Avatar
so get one used?!!
Yep, probably gonna go that route, I'm so new to these Trucks I wanted to be sure I wasn't missing something unique.
Still better that 223.00!!
Old Dec 19, 2006 | 10:12 PM
no, i meant the new one is the one you have to depin. the used ones are complete assy's.
PM me if you are interested in buying a used one from us (nix99)
Old Dec 19, 2006 | 11:12 PM
son209's Avatar
Have you checked the fuse for the low beam lights? I use to have a 90 nissan 300zx that I ran higher watt bulbs in that would pop the fuse after about 4-5 months and when it did that my low beams and parking lights would go out but my high beam would come on untill I put a new fuse in.
Old Dec 19, 2006 | 11:23 PM
SLC97SR5's Avatar
I have not checked the fuse...I'll hit that in the morning...how gay would that be? Pull the columm just to have a bad fuse.
Old Dec 20, 2006 | 05:42 AM
myyota's Avatar
You might try replacing the head light relay, when i got my truck a few months ago the headlights would only work on high beams, it turned out to be a bad head light relay. I got another one from pic n pull and put it in and all was goot again.
Old Dec 20, 2006 | 09:07 AM
4runnerx3's Avatar
My Datsun z-car would only work on high beams years ago. Took it to a Nissan dealer, they had 4 guys on it for about 3 hours and they couldn't figure it out. Well, one night my girlfriend turn to put something in the hatch from the seat and she push on the upper carpet with her feet while doing so and I noticed a change in the lights. So I found there was a main harness plug for the lights under the carpet on that side and it was corroded from where a bypass hose on the heater core burst about 2 years prior. Short version- might be a bad connector somewhere in the harness.
Old Dec 20, 2006 | 09:10 AM
19RUNNER86's Avatar
leave them on and blind people. if it doesnt blind you... good to go.
Old Dec 20, 2006 | 09:59 AM
4Crawler's Avatar
If all the combo switch contacts close and open normally (i.e. none of the contacts are welded shut), then you may have a short to ground someplace along the wiring between the switch and the lights. Since the lights come on when either the high or low beam side is grounded (by the combo switch), any short to ground in that wiring will cause that light to come on all the time:
westonian18
May 1, 2020 06:38 AM
fountain
Dec 31, 2015 06:08 AM
trucker trash
Jul 28, 2015 10:09 AM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
