Suspension Suggestions For 84
Old Dec 11, 2006 | 07:05 PM
THEYOTAKID's Avatar
Im A Broke Kid Just Out Of Highschool. I Just Recently Got Into 4x4's About 2 Years Ago. I Bought An 84 Yota Pickup And Im Lookin For Some Way To Get Better Offroad Performance Without Spending Outrageous Amounts Of Money. Lookin For Suggestions. Suspension Lift? Body Lift? Etc. Lookin To Spend Round 500 Right Now. It Has Stock Everything Except For The 31x10.5 Tires
Thanks Guys
Old Dec 11, 2006 | 07:11 PM
85badger's Avatar
Go to pirate4x4.com and read the FAQ's before posting, you should fine alot of info there.
Old Dec 12, 2006 | 05:11 AM
fourwd1's Avatar
What type of offroading do you do?
A suspension setup for mud wouldn't be the best for rockcrawling, for example.
And how much lift are you looking for?
For $500 you could probably get a kit form one of the cookie cutter suspension companies (Rough Country, Pro-Comp, etc.).
Old Dec 12, 2006 | 05:42 AM
THEYOTAKID's Avatar
I Am Usually In Mud More Than Crawling But Thats Only Because Where I Live Is Mostly Flat Land (ga) I Would Like To Have A Suspension That Would Do Alright For Both Is That Possible?
Old Dec 12, 2006 | 03:49 PM
harpen123's Avatar
what would u do differently for a mud truck then a rock truck?
Old Dec 12, 2006 | 04:14 PM
paxil4x4's Avatar
Drama Queen/Banned
Locker
Old Dec 21, 2006 | 10:14 PM
idayota's Avatar
if you are interested in serious rock crawling/trailing, then you would want something with some flex (i.e. longer, flexier springs than stock...all-pro off-road, marlin crawler or chevy springs in rear and toyota rear springs in the front). if you are mostly interested in getting some hieght and are not as worried about the flex, then a cookie cutter lift is gonna do great for you. this would work well if you want it too look tough on road and do ok in the mud. too flexy of a spring in the mud isnt good. you'll get lots of axle wrap when you try to put the power down. 3-4 inch kits from rancho, superlift, etc should be in your price range and should include the necessary changes to your steering and brake lines and you shouldnt have to do too much to your drive lines (like nothing if you are ok with some vibrations.) i've run both superlift and marlin crawler 4 inch springs. the superlifts did great for what they were, but someday, down the road, you'll have to check into marlin or all-pro springs...they ride awesome on road and do even better off road. that's my $0.02.
Old Dec 25, 2006 | 01:52 PM
THEYOTAKID's Avatar
thanks for the input it helps alot. i need new front springs regardless mine are shot they sag horribly also what do chevy 63 springs come off of and what do you have to do to put them in the rear?
nvdesertrunner
May 11, 2020 08:18 PM
89fourrunner
Feb 17, 2016 06:52 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
juandulce4runner
Aug 21, 2015 07:30 PM
Vargntucson
Jul 4, 2015 12:15 PM
