Towing with 92 V6 4runner with auto trans
Old Nov 29, 2006 | 08:01 PM
Slime green cat's Avatar
Just wondering how the auto trannys in these hold up while towing ???
I just picked up a mint 92 4Runner v6 auto , and I want to use it to tow my Yamaha Rhino on a 5x10 trailer .
The whole package is about 2500lbs , and I will be towing in the mountains .
I tow this set up with my other 92 runner all the time without a problem , but its a 5spd .
I once heard that the auto's in these were on the weak side , but dont know if there is any truth to that .....
Will the auto tranny hold up towing that much weight ??
Thanks for any input
Old Nov 29, 2006 | 08:04 PM
toyota_mdt_tech's Avatar
You are good up to 3500 with the A340H tranny, shouldnt be a problem.
Old Nov 29, 2006 | 08:17 PM
Wow , thanks for the speedy reply .
Would that 3500lb limit be with an optional tow package ?
Mine does not have the tow package (if it was even available)
Are these particular tranny's good ? no issues with them ? like I said , I once heard they were a weak tranny , but this truck was just so mint and such a good deal , I figured I would take my chances . So far I like the auto tranny , I have had several Toyota trucks and 4Runners , but all have been manuals .
Old Nov 29, 2006 | 10:31 PM
Old Nov 30, 2006 | 01:39 AM
91 4Runner's Avatar
I use to tow 2 snowmobiles on a double skidoo trailer (with 6 extra gas cans0 with the truck fully packed for a week at our cottage and then drive 391kms (1 way) to the cottage with mine (no issues) but I did add an extra tranny cooler for that just in case....
Old Nov 30, 2006 | 06:41 AM
intense's Avatar
Where and what kind of tranny cooler did you get?
Old Nov 30, 2006 | 07:09 AM
slosurfer's Avatar
here's the info on where I got mine and how I mounted it
https://www.yotatech.com/forums/f116/transmission-cooler-mounted-behind-grill-pics-86774/
YOu will definately use the od off button and the ECT button while towing. In the mountains you may also have to have it in 2nd for awhile.
Old Nov 30, 2006 | 04:54 PM
Thanks for the replys guys
I guess I will go ahead and put a hitch on it and see how it tows with the auto .
I may look at putting a tranny cooler on before summer .
Thanks .
Old Nov 30, 2006 | 05:18 PM
itsmeagain5789's Avatar
yea, im thinking about a tranny cooler too, but will it cool the transfer case also?
Old Nov 30, 2006 | 05:28 PM
slosurfer's Avatar
If you have the tow package, you should have a little cooler that goes to the transfer case.
Old Nov 30, 2006 | 05:32 PM
is that right next to the fuel filter? because if it is, then I do have it, but it didn't come with the tow package when I bought it. I put a hitch on it afew months ago.
Old Nov 30, 2006 | 06:04 PM
slosurfer's Avatar
yes, that's the one. I had heard that it was from the tow package which didn't really make sense.
Old Nov 30, 2006 | 06:50 PM
That is for tyhe transfer case itself. Has its own little cooler! Late rmodels of the same generation didnt have them anymore
Old Jan 30, 2007 | 04:52 PM
Im going to open this back up, because i'm gonna start towing pretty soon. What do you guys think about towing an 18 ft bayliner (boat) with my 3.0 auto. the boat with the trailer weight is about 2800 pounds. we are thinking about a keys trip which is about 600 miles south and then back. I'm thinking that with all the luggage and the 4 people in the car, that this will probably be over 3500 pounds. You guys think i should go with another tow rig, or can she handle it? the 4runner doesn't have a tranny cooler, though I will probably put one on if I decide to use it. let me know what u think.
Old Jan 30, 2007 | 05:17 PM
Kyle95sr5's Avatar
I tow a 20 ft enclosed trailer loaded down with all sorts of wood and saws and other various stuff everyday in the summer for my job. Never gave me any problem but Ill be installing a tranny cooler this upcoming summer considering ill be going into the job full time.
Old Feb 1, 2007 | 03:35 PM
leebee's Avatar
get a hayden cooler, comes with all the instalation instructions. youll need a length of flat stock to make a pair of 'brackets' to bolt under your front skid. check out robinhood150 for some pix and tips.
i put one on my 93 last summer and used it to tow a camper several times, worked like a charm. be forewarned, your fuel consumption will be much higher as you will have your o/d button 'OFF' for towing. long flat stretches you might get away with having it on but for any type of hills turn it off.
you might also consider having your tranny serviced, ie new fluid. you can do the other drive line fluids yourself, fr/rr diffs and t/case. check your u-joints while you are under there. nothing worse than being half way to your destination and finding out one is on the way out.
lee
Old Feb 1, 2007 | 03:46 PM
slosurfer's Avatar
Here is another way to mount a cooler. https://www.yotatech.com/forums/showthread.php?t=86774
Puts it right where it is suggested. When in 4lo I run super cool because the engine fan pulls air through the cooler. Down behind the skidplate you won't get much air flow when you are going slow, but shouldn't be bad for towing on the highway.
Old Feb 1, 2007 | 04:28 PM
thook's Avatar
Hmmm....I have a 92 4nr and bought a cooler from O'Reilly. The package came with these unique zip-ties....really strong, BTW. Anyhow, I didn't feel like cutting on my grill...was just wanting to get the cooler in quickly. So, I pulled the skid plate off, cut a piece of coated hardware cloth to make a grill for behind the plastic trim that's under the bumper. Fastened that in and mounted the cooler up behind it. I'll have to get some pics up, but it was less work and cutting and has held in really, really well even on my bumpy country roads.
Also, if your going to tow alot like I do, sythentic tranny fluid and a remote filter is a very good idea. 2 cents....
Old Feb 1, 2007 | 05:09 PM
4runnerx3's Avatar
Whatever you tow, be sure to turn off the OD.
Old Feb 1, 2007 | 05:46 PM
LS1Steve's Avatar
I have a 5sp but have towed a 22ft four winns boat frequently. as far as power, its not the greatest but it will move it around well enough
RyanJ989
11
Apr 7, 2021 09:41 AM
Bourbonblues
Dec 15, 2017 05:43 PM
Odin
Sep 26, 2015 06:56 PM
mojo4x420
Sep 16, 2015 08:07 AM
seab1209
Sep 3, 2015 05:41 PM
