Check motor
Check motor
My check motor light came on the other day. all the fluids are full and new. i just put in a new air filter. vaulve oil filter and fuel filter. my trucks got 206k on it is this just a flaw or do i need to worry?
will i see your new but around here we like to call it cel short for check engine light ..... what kind of air filter? could try resetting the ecu by pulling the negative battery cable and the efi fuse
oh ok i just bought it a month or so ago i havent drove it yet but my dad has been. i ate it on my quad and a little messed up so.. next week i think i can start driving
To check for TDC (Trouble Codes) see link below and jump TE1 to E1 terminals. Turn ignition switch to run position and count the blinks of the CEL.
http://www.troublecodes.net/Toyota/
I know its off subject, but, where is the list of stuff not to use on my toyota
And I use an OEM air filter. I used to have a K&N but someone put up a poll and posts after that convinced me that K&N wasn't doing me any favors out here in the desert.
I find that when I don't use OEM parts, I end up servicing my vehicle more often.
eg.
I got 3 brake master cylinders through Checker/Schucks/Kragen for my Land Cruiser, none of which lasted longer than 6 months before a seal went bad, leaked, and my brakes went gushy.
Finally, I bit the bullet and bought a new OEM toyota master cylinder through the dealership, put that on, and I haven't had a problem with it in 2 years.
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
