Starting problems after rebuild
Well after dropping back in my engine (22re) got every thing hooked up and go to crank it and i just get a single click, i think its just the starter im gonna take it back off and take it to advance auto to get it tested, but could if possiblely be a bad ground some where, also i saw that my injectors leak really bad now cause of the seals that were all dry rotted, i was wondering where i could get some new ones.
As for the starter, it sounds like a classic case of bad contacts. Although since you just RNR the engine, be sure to check all of your ground connections. As for the leaky fuel injectors, I would just get injector seals at the dealership although any aftermarket ones will probably be fine.
Had this problem with mine when I first got it. On my 84 22r, the power from the battery hooks straight on the starter, with a smaller leg going off to the fuse box. So where is the 2nd leg or ground leg for the starter. On mine there was a small wire that ran from the block to the frame. But when the last owner rebuilt the rig he never reconnect the ground strap. For a quick check I ran a jumpper wire from the ground on the battery to a spot on the block. Motor turned over like it was happy and fired right up. So I then ran a ground wire from the battery to a spot on the motor. I have had no more problems with the click or real slow turning starter when it does spin.
the1998sr5
Oct 19, 2016 12:48 PM
jennygirl
Nov 17, 2015 11:24 AM
aciorba23
Jun 29, 2015 04:18 PM
