ID this gasket
Old May 15, 2026 | 01:28 PM
Eighthnote's Avatar
ID this gasket
Hello all, at the top of the 3.0 motor in my 1993 SR5 4x4 I've looked and looked for the gasket that goes in between the housing where the upper radiator hose is mounted. There's nothing in there (but nasty which I'm trying to clean out) it just looks like a L housing for the return hose. If you know what that housing are is called that might help. Again, just looking for the gasket.
Thank you,
I moved the top of the housing and hose out of the way so you can see it.
Old May 15, 2026 | 02:58 PM
the_supernerd's Avatar
Toyodiy.com does not show a gasket for it, and there are quite a few people online who say the FSM calls for FIPG not a gasket. I only have an FSM for 22R trucks so I can't verify it myself, but I have personally used RTV for that part on a 3VZE and it worked fine and held for years.
The part is called a water outlet, part number 16331-65020
Old May 16, 2026 | 04:08 PM
Eighthnote's Avatar
Thank you for the info. That's what someone did to this housing. I'll pick up some RTV and clean it up and deal with that soon.
Thanks again...........
Camaro1976
Dec 9, 2012 03:54 AM
92Yoda
Jun 4, 2011 03:20 PM
shansethp
Sep 14, 2010 08:12 AM
wesshole
May 31, 2010 03:12 PM
ctcost
Apr 2, 2005 08:29 AM
