88 22re Throttle cutting in and out.
Forgive me if this issue is addressed elsewhere, but go with me for now. Today driving down the highway in the rain, my throttle seemed to just stop working. I'll try my best to explain everything. I was in 4th coming into a town, put the truck in neutral coming to a light. When the light turned green, I put the truck in 1st, and the gas was intermittent. Would rev, then nothing, rev, then nothing.....and so on. I pulled over. Popped the hood and manually played with the throttle. Again with the throttle engaged, rev, nothing, rev, nothing. I checked a few wires, tried again, she ran. About an hour later on the highway, same issue happened, this time while at speed. Pulled over checked a few wires again, throttle did the same rev, nothing, rev, nothing nonsense(I should mention it idles perfectly.) It once again corrected itself for an hour or so. I am now at a hotel somewhere in TX because this has happened about 5 times today. Any clue as to what the issue could be? I was thinking maybe fuel pump going out???
Sorry if this is all jumbled and doesn't read well. I'm super frustrated as I am only 5hrs into a 1700 mile trip back home, any help would be greatly appreciated.
It is hard to tell without actually being able to see the truck for myself.
Can you post a video of what the engine is doing?
It is possible that the fuel pump is on its way out, but without measuring fuel pressure, I could not be sure.
How did you check the wires? Which wires did you play with?
Did the "Check Engine" light come on at all during this trip?
I am not sure if a bad Throttle Position Sensor (TPS) could cause these exact symptoms, but is another likely potential cause.
Do you happen to have any tools with you? Maybe a multimeter?
Being far from home limits what you are able to do. If you are not really mechanically (and maybe electrically) inclined, taking your truck to a shop may be your best option.
What I mainly meant by checking wires, was looking for breaks, or any obvious disconnects in the engine bay. I was thinking that maybe because it has been raining so much that water may have caused a short. I checked all obvious connections, under the hood by making sure they were properly connected. I do not have a multimeter with me, so just having to rely on a visual/physical check.
I made sure everything from the coil/plug wires were all plugged in properly, checked the connections going to the fuel pump.
The check engine light is unfortunately in a constant on position due to the previous owner doing a smog delete and simply cutting the O2 sensor wire.
The tools I have with me are very minimal. I have enough sockets and what not to deal with most things on a Yota. Though nothing for checking voltage/continuity.
If it's doing it only when there is moisture... it's the distributor... it takes a TINY bit of moisture to cause some serious issues like your describing...
While it's dry and running good, take the cap off and put a little silicone inside the lip of and seal the cap... dielectric grease would work also and you can use a touch of it on the inside of spark plug boots... both ends... to help water proof...
my 22rte did the same thing but only when it was raining or if washed it at the car wash...
my cap was missing the o ring that seals it, so I did what I'm suggesting till i got the proper o ring and installed it... no more " random" dying when it's raining... or should i say no throttle issues... it wouldn't die, would idle, just no throttle till it cleared its throat and would run fine till it got moisture again... not even wet .... just moisture.
spraying wd-40 in the cap might be a temporary fix and orielys sells a spray on water proof product for ignitions... i don't remember what it's called...
good luck i hope you make it home ok.
jubba_bones (12-07-2018)
Awesome, I will look into the distributor issue in the morning. I would love an easy fix, as I've already had to replace the starter in a Wal Mart parking lot on my trip to Texas.
Yeah, thats one of the problems right now. It hasn't stopped raining since this issue has started. I'm hoping the hotel will let me park and work under their awning tomorrow, otherwise I'm going to throw a tarp over the hood and go from there.
Find the nearest Harbor Freight and grab one of their cheap multi meters for testing the throttle position sensor. Hardware and parts stores have them also, not as cheap probably.
Symptoms of a Bad or Failing Throttle Position Sensor
the TPS doesn't usual "clear up" then start acting stupid again... it works, it's out of adjustment, or doesn't work... but not intermittent or randomly....
- Car won't accelerate, lacks power when accelerating, or accelerates itself. ...
- Engine won't idle smoothly, idles too slowly, or stalls. ...
- Car accelerates, but won't exceed a relatively low speed, or shift up. ...
- Check Engine Light comes on, accompanied by any of the above behaviors
Just pulled the distro cap, no o ring......going to throw some dielectric grease on the plug ends and on the lip of the cap and will throw an o ring in for good measure. If this works, I will let y'all know the next time I have internet. (hopefully thats when I'm back in Nevada.)
You don't owe me... glad it fixed for problem... have a blessed weekend...
Cool!
What did you find out though? What was distributor like before you cleaned it?
Next time it rains, also check ECU and surroundings behind the right-side kick panel. Where wires enter the cabin from wheel well sometimes leak.
it took me forever to figure the moisture thing out... my cap was perfect, It took many scenarios before I was able to definitively blame moisture for the problem.... When I checked the cap ( several times) there was never ANY sign of it being wet....
but, i was convinced that was the problem so I started water proofing and it totally fixed all my miss, acceleration issues... i guess what I'm saying is it's not easy, nearly impossible to detect other than going by the symptoms and the connection with moisture, whether in the form of rain, fog, snow, sleet, drizzle, car wash... but, i know it takes very minute amounts of moisture to create some serious issues...
As far as my ECU, I have no kick panels installed, so I know that there was no obvious build up of water in or around that area.
BrianAZ
07-21-2014 10:16 PM
JollyGreen
11-25-2009 07:42 PM
Randomness
05-21-2005 03:07 PM
