[Help] Engine Turns over but wont start without Gas Pedal
Hey so i have this problem where my engine will turn over and not start unless I give it some gas. For whatever reason if I don't do the current starting procedure right the first time it's a lot harder to get it going afterwards. Once it's started up it runs great. After some reading I'm suspicious of the throttle body sticking at start or the fuel filter so I plan to replace/clean both of those later today/tmw morning. Any suggestions?
When you say runs great, it's been driven about at various speeds and doesn't stall, or just idles fine? No CEL?
Has it been sitting out for some time?
Fuel filter not suspected in these cases but better to replace if it's time.
Are you able to hear the fuel pump turn on when you first turn the key to ON position? Like a soft buzz noise for a second right after the key is turned, but before you turn to crank/RUN? That should mean you're getting fuel pressure, though there's an actual tool for measuring that.
I think you're on the right trail with a sticking throttle...worth taking a closer look at.
CEL light is on for running lean but that just recently came on and this has been a problem for a couple weeks. Not sure what you are asking by "Just pray tell are you working on". its a 98 3.4 5 speed at 158k
the possible culprits.
Idle air control valve could be playing silly buggers while the crud in it is cold and solid. when it warms up it operates a bit more fluid.
Or it could be completely malfunctioning leading to an idle dependant on suction pulling the idle control valve open.
Or there could be a vacuum leak somewhere, which was once small enough to cause problems at the most mixture critical time, (startup), which is now becoming worse, so much worse that it is effecting the ECU during normal operation and is now throwing a code.
RampartRanger
04-10-2017 03:00 PM
wyorunner
04-23-2009 07:32 PM
DirtNWaterMakeMUD
01-13-2009 04:42 PM
