Clueless Wire Identification
Old 12-09-2017, 05:31 PM
MDman100's Avatar
I gots a 1993 Toyota 22re manual truck 2 plugs no clue where they go the one that has a yellow connector on it is tied into the wires that lead to the transmission the other one looks like a power wire of some sort 3 brown wires 2 on the left an 1 on the right on the left on the connector it has a R on it so no clue what that means this truck was saved from the junk yard and was jerry rigged pretty good for the wiring re done the whole truck an new engine i want everything to be stock so that yellow connector isn't stock and may need to get the right plug if we can identify it.
Old 12-09-2017, 06:55 PM
scope103's Avatar
Breathe, MDman100! That's it, take your time.
Your 125 word question was posted as a single sentence. Periods and commas aren't expensive, and they'll make your questions, well, intelligible.
The right-hand circle in your picture is around the ground wire, to be bolted to a cam cap. The other wire isn't stock, but beyond that you haven't given me enough to go on.
Old 12-09-2017, 07:16 PM
MDman100's Avatar
Sorry Scope103 I'm not the greatest about all that periods and commas and spelling lol. Now when you say cam cap I'm confused on that never heard of that i thought it would go to something on the lines of the aluminum intake manifold but i couldnt see it being a good ground. The yellow connector is branching off the wire harness leading to the transmission. The same harness with the connectors going to the starter.
Old 12-09-2017, 07:18 PM
MDman100's Avatar
Hey Scope103 sorry scratch the cam cap off the bottom stud coming off the intake manifold is what your meaning
Old 12-10-2017, 06:54 AM
92ehatch's Avatar
Yes the one on the right is a ground, to the bolts that attach the lower and upper intake manifold.
the other may be the starter solenoid but it is not factory as previously stated so i can't be sure.
Old 12-10-2017, 11:32 AM
maco35's Avatar
The 3 wire one is #4 in this thread. https://www.yotatech.com/forums/f116...-guide-194413/
89possom
10-08-2010 04:56 PM
headstomp3
02-03-2010 07:54 AM
yota yota yota
09-16-2009 07:39 AM
91muddog
07-11-2007 11:27 PM
Quick Reply: Clueless Wire Identification
