testing a fuel sending unit....conflicting info???
Old Apr 21, 2012 | 06:16 PM
full_throttle's Avatar
greetings,
I have been troubleshooting a gas gauge problem on my 1999 4-runner, and in my research I have come across what appears to me to be conflicting information.
Several people have cited this website for troubleshooting the fuel gauge system. One of the links at this site has the following information for a 1999 4runner;
"INSPECT FUEL SENDER GAUGE
Measure the voltage between terminals 2 and 3 for each float position.
If resistance value is not as specified, replace the sender gauge
Even though it says to measure the voltage, I am sure it means resistance. So, according to this page, the resistance should be between 4.6 ohms and 0.3 ohms depending on the amount in the tank.
NOW, compare that to to what I have found on 1996 to 2002 Toyota 4Runner OEM Repair and Wiring Manuals specifically HERE
The important stuff is on pages BE-51 and BE-52
Note how to test the resistance of the sending unit, and how to check the gauge.
Measure the resistance between terminals 1 and 3 in each float
position.
Float position: mm (in.) Resistance (Ω)
F: Approx. 39.4 (1.551) Approx. 184Ω
1/2: Approx. 56.0 (2.205) Approx. 97Ω
E: Approx. 148.9 (5.862) Approx. 12Ω
The differences are the pins to measure and the measurements themselves.
Can anyone confirm which way is correct?? When I measure using pins 1 and 3, my resistance measurements are in line with the chart, but when I use pins 2 and 3, they are way off....
I am not sure what to think here. I tend to believe the 2nd one since it appears to be from the FSM, but the first one looks legit as well??
Can anyone with a known working system take the time to take these measurements and confirm which set of instructions are correct?
Old Apr 21, 2012 | 06:21 PM
BajaRunner's Avatar
FYI The fuel gauge reading on these trucks are pretty bad. I've owned 3 and none work very well.
Old Apr 22, 2012 | 10:50 AM
toyospearo's Avatar
I second what BajaRunner is saying.
Out of 4 pre 95 yotas I have owned/own none of them were dead on. Mostly they were pretty far off.
Old Apr 23, 2012 | 07:17 PM
I understand and agree that the gauge has issues. What I cannot seem to find out is which of these two methods for testing a sending unit is correct?
Old Apr 24, 2012 | 02:29 AM
suncomb1's Avatar
Go to your local Toyota dealer and ask them which is correct, most Toyota dealer service managers are always willing to help. I use a factory service manual for servicing my truck (1983) and the information in them has always been correct.
Old Apr 24, 2012 | 03:39 AM
xxxtreme22r's Avatar
I'd be willing to bet the FSM is correct and not the other website.
Old Apr 25, 2026 | 10:22 PM
Stucco17's Avatar
Testing New Fuel Gauge part # 8332035590
I just recently had a fuel gauge problem and managed to fix it (It was a melted terminal on the back of cluster board) link here: https://www.yotatech.com/forums/f2/3...l#post52504493
During the course of troubleshooting, I did the test both ways (Haynes manual says terminal 2 and 3, FSM says 1 and 3..FSM is right apparently)
2 & 3 got me a reading of 203-205 constantly regardless of float arm position
1 & 3 got me reading of approx 180 in top, 100 in half, 12 in bottom (its the exact opposite of what it says it should be but it measured very accurately)
Try cleaning all the metal on the fuel sending unit and resolder, it might help (Idk if it helped me but I did)
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
