Windows Media Player 9 help needed
I mistakenly posted this in the other Off Topic forum, which should give you an idea about why I'm having computer troubles:
Suddenly Media Player won't run any streaming video at all. From troubleshooting tips on the web, including the MS site, it appears I have a corrupted .wmv codec, maybe other stuff going on too. The steps I've tried, including a system restore, had no effect.
I've done all the virus scans (Housecall and NAV), Adaware, Spybot, re-associated file types, sfc, system restore, and I've forgotten what else. Today I tried additional "fixes" posted on the web, and Corey's idea to reinstall DivX and MS codecs but none worked. I can't find any way to R&R MP9. I'm almost at the point of calling Bangalore, but have received far better advice from techies here. Any ideas? TIA.
Oh are you getting any type of error message ?
Also have you simply tried re-installing Media Player from the Microsoft site and let it over right any files with problems.
http://www.microsoft.com/windows/win...es/player.aspx
Thanks WT. It's a newer Dell box. CHKDSK didn't do anything, no error messages either. I'll try re-installing MP next. How would I go about an in-place XP Pro repair? I'll let you know how the MP overwrite goes.
The MP re-install didn't help.
http://support.microsoft.com/default...b;en-us;315341
Other option is if Dell supplied a set of retore CD it will get you back to the day you got the PC and maybe a option depending on how annoyed you are with the problem. THIS WILL LOSS ALL DATA just a warning too
Just ideas .. so are you not getting any error messages when you try to stream something and is it just audio(radio) or video too ??
Good Luck .....
Dell supplied a full set of software to return it to Day 1. No error messages, I get audio fine, no video at all. This happened just as I was about to install my new DVD burner, so I'd like to get it straightened out before installing Nero that I'm thinking could need WMP for playback.
I am not a computer guy at all but I had the same problem! I had to I had to delete the program (from the start- contol panel) then go this web site http://www.microsoft.com/downloads/s...displaylang=en and look up your info for there.
It will wipe out all your vid's that you have!!!!!
Give it a try?!?!?!
It will wipe out all your vid's that you have!!!!!Give it a try?!?!?!
Thanks NX, but WMP 9 isn't even listed in the Add/Remove part of Control Panel. From what I've read on different sites, it isn't possible to delete it, but is doable for earlier versions.
Originally Posted by NX Tacoma
Ok try under All Programs, then you will see Windows Media Player....right click to delete.
Try this...
- Go to Control Panel
- Pick "Add or Remove Programs"
- In the left frame, pick "Add or Remove Windows Components"
- Scroll down the list, and UNCHECK "Windows Media Player"
- Click NEXT
- WMP should be Gone
- Reboot the system
- Head Here and re-install Media Player 9
- That SHOULD help.
I doubt that you corrupted the codec, it sounds like something got installed that took the responsibility of video playback.
Thanks, Mark. I did what you listed, first running Chkdsk and Defrag before re-install. No change in the symptom. I didn't install anything I'm aware of prior to the hiccup. Hmm...
I know what you mean. This is the first problem I've had with this computer since new about a year ago.Here's a typical clip from MS WMP movie trailers.
Direct from MS site
Clicking on "Watch the trailer" gets audio only.
Okay, so it's just a 1-pass CBR video at 35Kbps done with the Media 9 codec. That should even play on my phone!
Can I ask you to try a couple of other things? Do any of these work? (they're all "safe for work", it's just misc stuff that I have on my server that use different codecs):
http://www.midiwall.com/misc/GasPump.avi
(video, no audio. OLD codec)
http://www.midiwall.com/misc/TysonSkating.wmv
(16Kbps, 1-pass CBR Media 7 codec)
http://www.midiwall.com/misc/HSNKnives.mpeg
(MPEG codec)
(fingers crossed...)
(MPEG codec)
Co-Founder/Administrator
You know what might be another problem, some vids require you to use codecs from this site.
http://www.divx.com/divx/
If you get the codecs, go for the free ones, but not the "add supported" 0nes.
http://www.divx.com/divx/download/
Also do not install their player.
You won't need it since you have MS Media Player 9.
Also have you kept up on updating your vid drivers?
Vid drivers get updated quite often.
ATI who makes my vid card releases new drivers about once a month it seems.
Since you have a Dell, when you go to the Windows update site and brose to the new drivers, it should give you Dell video drivers since MS will reconize you have a Dell.
Corey, yeah I d/l'd all the DivX codecs. No change. I visit Windows Update daily for Critical Updates and look at driver updates. Nothing there for Dell or on the Dell download site. I uninstalled Quicktime tonight, but no change there either. Still searching, thanks for the suggestions.
With Quicktime now uninstalled, reboot, uninstall media player, reboot again, and install media player.
Let's see if that shakes things up... If it doesn't seem to help, then try this download:
http://www.microsoft.com/windows/win...es/codecs.aspx
That'll pull JUST the latest codecs and force them in.
I've asking folks around work as well, (I work VERY closely to the product that you're having trouble with
) and we're all kinda' voting against Quicktime right now. (biases aside
Mark, I did everything you listed in order, plus ran chkdsk and defrag before WMP 9 reinstall, and also uninstalled Firefox. I tested with the MS link I gave...no change, no video, just audio.
I'll try anything else you suggest (short of re-format!). I need to get this straightened out before installing my new DVD burner.
I'll be out this afternoon getting a house ready to sell, and all day Friday through Sunday running an open house (in 100° heat). I'll check back evenings for more tips and tricks. Thanks again!
