UT 2004 Frag Fest
Old Jul 2, 2005 | 05:34 PM
  #121
Corey's Avatar
Co-Founder/Administrator
Let us play
Old Jul 5, 2005 | 05:55 PM
  #122
Corey's Avatar
Update!
Member Drew as you may know from some of my other threads here is renting two very fast servers based at the Westin Hotel in Seattle.
The download speed is around 22,000 kbps compared to the 4,000 kbps I get with Comcast.
He got the server setup with UT 2004 on July 4th, and I did some tweaking for the game styles and maps.
We have some mroe things to work on such as enabling voice chat in the game, but the server smokes.
If anyone here with the game would like to test out the speed, games, and maps, the IP is:
64.246.174.203:7777
Give it a try and report back here how it works.
We hope to have it all setup by Friday night.
Old Jul 6, 2005 | 10:07 PM
  #123
Robinhood150's Avatar
Yup, server works fine for me.
Old Jul 7, 2005 | 06:00 PM
  #124
Corey's Avatar
Bump...
OK, we have decided not to use UT 2004s built in voice chat, as it is not very loud, and not the best.
A much better app is called Team Speak 2.
http://www.goteamspeak.com/news.php
You need the Windows TS2 client.
ftp://ftp.freenet.de/pub/4players/te...t_rc2_2032.exe
Once you install the application, open it up and click on "settings" from the menu, then "sound input/output settings."
Bind a key in there for "push to talk."
I am using F, the same as it is in UT.
If you bind a key that is already used in UT, make sure you deactivate it.
So what this means is I have to unbind the F key in the voice chat area of UTs settings.
After binding your key, click on "quick connect" under the "connection" menu.
There you will enter the servers IP of 64.246.174.203, and then enter a nickname.
Leave the other 2 fields blank.
Leave the app running, then fire up UT.
The UT server also has the server side software running on it, and it will only be turned on during game time like Friday nights or on Saturdays to keep it from being abused
Hope to see a lot of you in the game Friday night.
I will try to make it by 7 PM, but I may be late, hopefully not.
I will bump this thread before I fire up the game Friday night.
I gotta Starbucks Double Shot drink waiting for me in the fridge, so I should be pretty wired to play the game
Old Jul 8, 2005 | 05:18 PM
  #125
Corey's Avatar
Bump...
45 minutes to go
Team Speak is turned on the UT server, so if you wanna test it out before the game, I have it running so you can talk to me, and you do not need to be in the game.
Have to eat first, and I will be watching Stargate Atlantis on the Sci Fi channel in the other room, but I will be able to hear anyone who talks.
Old Jul 8, 2005 | 05:26 PM
  #126
Not sure if I'll be able to make it tonight, something came up. If I do, I'll be late.
Old Jul 8, 2005 | 05:33 PM
  #127
Corey's Avatar
Hope you can make it Steve, Andy should be in tonight.
Old Jul 9, 2005 | 07:15 AM
  #128
Corey's Avatar
Well, I only saw Bruce in last night for awhile, but the server was working great for me.
Andy and I played until a little after 11 PM last night testing out stuff.
Normally when Andy and I game, we use our telephones with a headset/mic so we can discuss the game, plan strategy, ect.
We turned off the phones and fired up the Team Speak applet mentioned elsewhere, and it is one of the best two way PC communication apps I have ever had the pleasure to use.
We could hear each other just as well as using the phones.
I tired to unbind the F key in UTs settings, but it will only let you change to another one.
For an experiment we tried one of the side mouse buttons on our mice, and it worked perfectly in Team Speak.
No need to use a key on the keyboard.
With my side button setup to speak, I can push it and the main mouse button to fire at the same time.
I highly recommend you install the program for the next time we get together to play.
I will be off and on the server quite a bit today playing.
No need for an expensive mic either, I am using just a cheap PC mic, the kind that has been around for more than 10 years.
In fact mine is from '94.
You also can keep it about 1 to 2 feet away, no need to lean forward to speak.
Old Jul 9, 2005 | 08:48 AM
  #129
BruceTS's Avatar
yea I went in to test the server last night, no apparent lag issues, so it worked out great! Has to leave though(make some dinner) and then got tied up in other projects...
Old Jul 9, 2005 | 09:18 AM
  #130
Corey's Avatar
Cool, glad it was working OK for you.
I have it set now to advertise the game on Epics master server list, and also on Gamespy, so hopefully we can get more humans in there.
The game is also set so up to 32 humans can join in.
I will be turning on the chat applet in there in a bit, and playing for awhile.
I also added the Dana CTF map to the server earlier this morning, so if you want to try it, DL the map from my 4Runner server.
http://www.pnw4runners.com/index.php...e=ctf-dana.zip
You can then select the Dana map from the map list.
It is a hard level, and you only run straight back and forth to each base, but being out in the open makes you an easy target for the bots to pick off.
I like the classic Facing Worlds map from the old original UT, and the one they added with the same name to the 2004 one.
But we also played the newer Facing Worlds last night, and it is a lot of fun too.
You have to learn a few shortcuts to getting in and out of the base, but it was a lot of fun.
<iframe src="http://www.game-monitor.com/server-stat.php?ip=64.246.174.203:7777&text=000000&link=0 000ff&back=f0f0f0&border=d0d0d0&body=" width="200" height="210" frameborder="0" scrolling="no"></iframe>
Old Jul 15, 2005 | 03:23 AM
  #131
Corey's Avatar
Bump for Friday night.
I will be cutting out though to catch the 3 hour Sci Fi Friiday night starting at 8 PM PST.
Team Speak will be enabled Friday night and into the weekend.
Old Jul 15, 2005 | 08:37 AM
  #132
I don't think I'll be able to make it tonight, gotta fix a tranny leak when I get back from work. Then tomorrow I get to work in 106 deg weather to get my friends truck driveable for it's trip home.
Old Jul 15, 2005 | 04:15 PM
  #133
Corey's Avatar
I will be swapping over to Saturday nights starting next weekend.
Work is getting very heavy now.
I have much more time to game anytime Saturday and into the night.
I will be on tonight though from 7 until about 7:50 PM PST.
Old Jul 15, 2005 | 05:38 PM
  #134
iGGz's Avatar
Corey how many people usually play? I might have to pick this game up... I got sick of all the other games I use to play... heard this game is pretty sweet too...
Old Jul 15, 2005 | 05:44 PM
  #135
Corey's Avatar
This game is sweet Ian.
Aruond 3 to 5 of us play now, but I have "Advertise Server" set on, so it will show to anyone who fires up UT or Gamespy in the master list.
So we could get many more people in.
The way I have it setup now, anyone can vote for maps and we can also change the style of the game from all weapons to just the Instagib.
Here are some vids I shot in game.
http://www.pnw4runners.com/gaming/unreal/unreal.htm
And here is a page I put up showing links to the files you need to add so you have all the maps and the VOIP program we run.
http://www.pnw4runners.com/gaming/unreal/ut2004.htm
The graphics in this game are top notch, and the action is non stop.
I have 10 bots set up in the game too, so you can always battle them when logging onto the server if no humans are present.
Old Jul 15, 2005 | 05:54 PM
  #136
iGGz's Avatar
Do you need a CD key or anything like that when you install the game?
J/w
Old Jul 15, 2005 | 06:54 PM
  #137
Corey's Avatar
You sure do, so no one ever gives it out, or it locks them out of games on the Master server list.
Old Jul 15, 2005 | 10:52 PM
  #138
iGGz's Avatar
Thanks... you ever played Starcraft?
Old Jul 16, 2005 | 04:50 AM
  #139
Corey's Avatar
Sure have, still have it, the add on packs.
Also have the original WarCraft, and then the better one that improved the interface for connection over Battlenet.
Also have Blizzard's WOW installed right now, as my sons have an account for that game.
I am not really into the RPGs though, I like FPSs such as:
Unreal Tournament
Unreal Tournament 2004
Quake III Arena
Quake III Team Arena
Starwars Jedi Knight Outcast
Starwars Jedi Knight Academy
(I have the older Jedi Knight II and its add on pack Mysteries of the Sith from '99)
Starwars Battlefront
Half Life 2
See a pattern there?
Mainly all are FPS games.
Ut 2004 is my fave though.
A lot goes on in that game.
Old Jul 16, 2005 | 11:32 AM
  #140
iGGz's Avatar
Cool I'll have to check UT 2004 out for sure... then get good... and kick your A**
