Usb 2.0
Usb 2.0
I bought a Dell server and converted it to a desktop. I know that it has USB 2.0 capabilities, but I don't have the driver.
When I setup the computer, I installed the 875P chipset drivers and it still doesn't work.
I am trying to run my SanDisk usb drive, when I plug it in it says "high speed device in a non high speed port"
Any ideas on what I need to do to get this to work?
Specs:
400 SC
2.4 P4 H/T 800FSB
512 MB 400mhz DDR RAM
40 gig Seagate HD
60 gig WD HD
Running XP Pro
Specs:
400 SC
2.4 P4 H/T 800FSB
40 gig Seagate HD
60 gig WD HD
Running XP Pro
This may help:
http://www.aaltonen.us/forums/viewtopic.php?t=8
If I read that right. there are USB 2.0 ports separate from the USB 1.1 ports.
But, there's also a Q/A that says something a bit different:
And! There's a link on that page to updated drivers... Including USB.
Q. Does the motherboard support USB 2.0 on all ports?
A: Yes. ...
A: Yes. ...
Originally Posted by midiwall
Install SP1?
Have you tried calling Dell?
Dell won't support it since it was made to be a server. :pat:
Have you checked http://support.dell.com? They should list it. I have an IT Professional Small Business account there if you need to dl any drivers....
What about heading back to the fourm that I pointed to above and asking there?
Hey Travis... Any new info?
fwiw, I'm looking at buying one, so I may soon be sitting right there with you.
I do have two new pieces of info for you...
I'll keep you in the loop if I decide to join you!
- I hear that in order to get the USB 2.0 stuff to work, you have to buy a new front bezel from Dell. That doesn't make a lot of sense to me, but it came from a reliable source. I'm working on getting more details and confirmation.
- There are MB drivers from Intel that may help:
http://downloadfinder.intel.com/scri...p?Prod_nm=875p
(I think this is a new link versus one nested in the above links)
Mark,
Are you looking at the 400SC that is listed on slickdeals for $298?
If so, go for it, it is a damn good computer.
The front bezel that comes with the server is covering 2 usb ports and a headphone jack. The USB ports are wired and ready to go, the headphone jack is not wired. I ordered a wire for $5. I just cut a hole in the front of my bezel and can use the 2 usb's now.
Here is a little secret. Buy 512 mb 400MHz ram, then contact dell to do a authorized return, they will actually buy the 128 mb of ram back from you! I got $68 for my ram! If you don't need the hard drive, they will also buy it back. I ended up using the 40 gig seagate HD that came with it and installed a WD 60 gig HD that I had in my old computer. The total I have spent on this computer is just over $200. I am going to buy an AGP video card soon, then it has everything I want.
I am waiting for a new XP Pro from my friend that has a key that isn't being used. After that, I am sure it will work.
Let me know if you have any questions about the 400 SC
I think I already downloaded this driver, I will have to check when I get home. Thanks!
Yeup, that's what I'm looking at.
Interesting kick on the RAM buy-back, that's a nice little boost.
Argh... I REALLY should do this.
Thanks Travis!
Thanks Travis!
The 400SC won't allow you to mix a 128mb and 512 mb ram stick together at 400MHz, it will kick it down to 333MHz, so the ram is going to be worthless anyways.
Originally Posted by SLC Punk
umm ya sounds easy doesn't it. But I am running the same copy of XP on my laptop and desktop, so it won't let me download it again..
call microsoft and say your system crashed and your reinstalling it. they hack your computer and set a new serial number. I did it twice.
in the mean time u can download 1sp even sp2 from third party sites
Can't you just download the Network Installation version of SP1. Yes it is a much bigger download this way(134MB) but I dont think you'll have problems with the registration/activation this way. Dunno know enough about that last part....
http://www.microsoft.com/windowsxp/d...1/network.mspx
was given sp2 on disk by the it dept at work I assumed it was online. I've had it for a couple months from auto-update. they must of delayed again wtfs up with that
Really? You've found SP2 out there?
Care to share a link?
Can you do me a favor? Head to Control Panel | System and tell me what build that is? I'm curious about something I heard in another forum.
this system I built, what do u need to know? sp2 came from the microsoft update page. It's a legal copy "sort of" so I already have the updates. somewhat of a guinee pig. That why the reports say alot of the security fuction conflict with alot of things. I'd get one update one day my system woul act funny and lock up a couple time. a day or so later I'd get another update and the sytem would run fine. Now that the bug are just about worked out there finally releasing it
intel d850emv2
p4 2.4 at 533
1 gig pc800 rdram
200 gig drive
dvd+-R
creative audigy mp3
ati radeon 9200 128
zeelman 7400 cpu fan <--silent
forgettin some ˟˟˟˟
intel d850emv2
p4 2.4 at 533
1 gig pc800 rdram
200 gig drive
dvd+-R
creative audigy mp3
ati radeon 9200 128
forgettin some ˟˟˟˟
Oh...wow. You mean an internal auto-update from work or online?
