S video TV monitor
S video TV monitor
I have an S video out on my ati 9800 xt and a S video imput on the tv, however as soon as i plug in the cable into the tv it gets kinda fuzy, like bad reception. When i put my desktop on the tv the same thing happens.
Can i clear this up at all?
im no computer guy.. so maybe this is jsut a bump for you...
but i know that tvs use a differnt frame speed then a computer... that said... even though they hook up.. they might need a program? to make the wavelengths compatible...
I would try;
replace the s-vhs cable between the ATI video card and TV
verify the configuration in Windows for the TV as a monitor
FYI: TV's have a far lower resolution than computer monitors. I often have to set my TV monitor resolution to 800x600 to see a difference. Good luck
One turn the computer and the tv off
two plug the s-video in
three turn everything on
four on the computer right click on your desktop and go to properties. your in your dispay settings
five go to the setting tab, advanced , then monitors and hit the tv button
your tv should now show what on your screen. Some of the older video cards you had to play with the resolution to get it to fit your screen right but that one shouldn't, course you could just fork out the 2 grand for an hd plasma and use the monitor out
Originally Posted by PirateFins
You might have to tell the video card that you are using the s-video output.
I use DVI out to my Bigscreen and run 1024X768 and I can actually read things fine unlike on S-video, its still just to blury to read text.
ashamsuddin
17
Jul 22, 2024 03:59 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
