rundll.exe
Co-Founder/Administrator
You running XP???
Which folder is it in, and I can give ya a copy of mine.
Doing a search on my system, I am getting a few hits, but they are named slrundll.exe instead.
http://www.pnw4runners.com/temp2/dll_search.jpg
I am running XP pro what is happening is everyprogram that I try to open says:
Windows cannot find(what ever file name of program). MAke sure you tayped the name correctlly and then try again. To search for a file, click the Start button, and then click Search.
And I know that the programs are installed but it also happens with windows update and other windows based programs like calculator, notepad, wordpad, anything except Outlook and IE.
Did you do any cleanup of startup items recently ? add any new software ?
Yeah to all I know i had spyware/adware problems so i cleaned things up and added some programs to help with that. I think that i deleted to many files in my system and system32 folders. I tryed repairing with the windows cd and there was a list of system32 files that were missing and it still won't let me open anything.
So if you just need the rundll32.exe file leave me were you like me to email it to you at.
Have you tried also going back in time and using a System Restore point from before you started to delete files?
That may fix it.
PS, I do have a rundll.exe file as seen in my MSconfig running, 2nd down from the top.
http://www.pnw4runners.com/temp2/rundll.jpg
But it is part of a program called Tweaki which is a lot more enhanced than the Miscrosoft Power Toys "TweakUI" program.
That may fix it.
That may fix it.
That may fix it.
If all else fails you could always try a in place repair(re-install) of XP it will revert the OS file systems back to orginal dates of the XP CD you have granted you have a actually CD and not a rertore system CD from a manufactur type cds. Here take a look see if this is something you may want to try next, I have done it several times on a few machine with no problems only thing is you will have to run all the updates again since it will remove those files, plus it says make backup of important things just in case...
http://support.microsoft.com/default...&Product=winxp
Oh another option just popped into my brain, is just restore a single file from the CD, worth a try also before the re-intsall in place option:
Good Luck !!
windows cannot find rundll.exe
I used to have a similar problem. This windows cannot find rundll.exe solutions summary page helped me. Whiel its beginning contains some advettising fluff, skip it all and scroll to the bottom. The you'll find what htey call a manual slution methods and it worked for me.
Other possibility if that you have your real rundll.exe file corrupted. In suhc case I recommend you to run sfc.exe /scannow command from Start->Run dialog. It will search for corrupted files and recover them from your Windows CD. Good luck!
