Fooling with Apache
Old Feb 10, 2005 | 09:28 PM
Churnd's Avatar
Fooling with Apache
Let me know if anyone has any trouble seeing this page...
http://hearn.serveftp.com
Basically, I'm just learning how to run my own web server with Apache. It's nothing fancy for now, just trying to see if it'll work. It's running fine on my other laptop but I wanted to see if anyone else had trouble viewing it.
Old Feb 10, 2005 | 09:30 PM
WATRD's Avatar
It looks like an "under construction" page
Old Feb 10, 2005 | 09:41 PM
Churnd's Avatar
Wooooo Hoo!!!!!!
Rob, I figured maybe you'd know something about this. I downloaded AppServ which comes with Apache, MySQL and other little doodads. I probably need to read up on how to actually use it (i.e., make it more secure for my server), because once I figured this out it seemed a little too easy. Any pointers? I want to learn how to use MySQL but I don't know exactly what it can do.
Old Feb 10, 2005 | 09:43 PM
Poopshute's Avatar
what exactly do you wanna do? If you're just making an informational site you don't really need to make it any more secure than it is. I mean just make sure you permissions for the files you have are read only...
Old Feb 10, 2005 | 09:55 PM
WATRD's Avatar
Originally Posted by Churnd
Wooooo Hoo!!!!!!
The biggest deal to keep in mind with a webserver is to keep permissions as low as you possibly can. NOTHING should ever be permissioned to 777. 755 is all you will ever need and even then most scripts won't need even that. That is fully half the battle when it comes to security.
If you install PHP on your Apache/MySQL box, you have a SERIOUSLY powerful combination. PHP and MySQL are designed from the ground up to work together. It's still under construction, but take a look around the WATTORA site. The forum and all the members features are run via PHP and MySQL.
In answer to what you can do... with that combination, you can do anything you have ever seen on a website
Old Feb 11, 2005 | 05:10 AM
Churnd's Avatar
As far as permissions go...
I couldn't really find anywhere that included the numbers 777 or 755. I hope I'm not doing myself wrong by posting some of my .conf file here but I've found these sections and wonder if they have to do with configuring my permissions correctly...
# First, we configure the "default" to be a very restrictive set of
# permissions.
(Directory />
Options FollowSymLinks ExecCGI Indexes
AllowOverride None
(/Directory>
Or possibly another part...
# Controls who can get stuff from this server.
Order allow,deny
Allow from all
(/Directory>
I know it probably should be somewhere in that neighborhood of the .conf file, but don't know where...
To get some of the code to show up properly, I had to change the beginning "<" on each "Directory" to "("
Old Feb 11, 2005 | 05:30 AM
jacksonpt's Avatar
Senior Member
I've been using Apache, PHP, and MySQL for a long time. Open source is the shizzle.
Old Feb 11, 2005 | 05:48 AM
Churnd's Avatar
Fo' rizzle!
Old Feb 11, 2005 | 06:10 AM
WATRD's Avatar
777 and 755 refer to the permissions of the folders that contain your web facing files. Look up the term "chmod".
http://catcode.com/teachmod/
You are on the right track by locking things down. If in doubt, make things more restrictive and loosen up permissions as you need them, not the other way around.
Old Feb 11, 2005 | 08:17 AM
Churnd's Avatar
I'm running Apache in Windows, if that matters.
Old Feb 11, 2005 | 08:23 AM
WATRD's Avatar
Ah... I can't help you much there. I have completely abandoned Windows hosting in favor of *nix hosting.
Old Feb 11, 2005 | 08:48 AM
jacksonpt's Avatar
Senior Member
Assuming it's XP or 2000... click on the folder that contains your web files, click the security tab, and look at the permissions set for EVERYONE. Then do this for all the files/folders inside that folder. For all of these, make sure the inheritance checkbox is checked (lower left hand corner).
Set everything to read only... then increase the accessability as necessary. It'll probably take some playing around with, and it may very well get frustrating and tedious, but it's very much worth it in the long run.
Old Feb 11, 2005 | 11:42 AM
CynicX's Avatar
sweetness.....I was about to setup something similar or learn how too before I ˟˟˟˟ my computer up a little, regardless I got it back up and running....
Maybe you can post some link of where you downloaded apache and any information you have thus far. Then I can give it a try
Old Feb 11, 2005 | 11:44 AM
jacksonpt's Avatar
Senior Member
Apache is open source, which means it's free to the public. You can download the http server directly from the Apache site. Setup is pretty straight forward.
Old Feb 11, 2005 | 01:59 PM
Churnd's Avatar
Cynicx -
Here's what I've learned so far:
  • When you install Apache, you don't really "see" it running. It just creates a service.
  • Setup is pretty straightforward, and anything you enter can be changed in your .conf file later
  • It'll create a folder on your c:/ drive called "www". Anything you place in this folder will be made viewable online. Any html file labeled index will be the first page it looks for.
Old Feb 11, 2005 | 02:34 PM
CynicX's Avatar
I'm a bit confused.....where do you get the domain name from?....sorry I should really read up on it before asking questions.....
EDIT: I'm dumb, I dunno what I was thinking, I had the port closed in my router....derrhhh
Old Feb 11, 2005 | 02:56 PM
Churnd's Avatar
If I recall right, you signed up with no-ip.com, right? Well, whatever name you used for your FTP server, you can use the same one for your web (HTTP) server. It's just a name for your computer that's more handy to use instead of remembering and typing in a full IP address every time. The domain name just points to your IP address. That little program you downloaded updates no-ip to your current IP address in case it changes. If you had a static IP (which costs more), you wouldn't need that.
So, once you get Apache up and running, your address would be http://cynicx.myftp.org.
Your domain name is cynicx.myftp.org.
Old Feb 11, 2005 | 02:58 PM
CynicX's Avatar
lol if you click that link you'll see my progress....
Old Feb 11, 2005 | 03:09 PM
Churnd's Avatar
Great, that means you have it up and running. Now all you do is design web pages to reside in that folder. As far as the structure of how to maintain that folder, I'm not 100% sure. I think you should be able to create other folders for different web pages as long as you point to them correctly through the index.html file.
That page you see right now is just a pre-written html file that came with Apache.
I think you should also be able to host as many sites as you want through different domain names as long as you edit the .conf file correctly and create different domain names for them.
Old Feb 11, 2005 | 03:12 PM
WATRD's Avatar
Pages are served up via the following scheme;
You can use any of the following (listed in order of priority):
index.htm
index.html
index.shtml
index.shtm
index.php
index.php3
default.htm
The root page, the page that people see when they hit the domain must be in the root, but from there you can build any directory structure that you may desire.
