GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
*QUESTION* just got a CB...
Old Oct 15, 2004 | 09:23 PM
4RunnerKid's Avatar
*INSTALL DONE, THANKS* just got a CB...
Well, I just picked up a CB. It's a Midland 40-channel digital. Where have you guys mounted yours? This one's only like 4.5" wide. Here's a pic:
Also, where did you guys with 4Runners mount your antennas? I would like to mount it on the rear bumper. Thanks for any help you can provide.
Last edited by 4RunnerKid; Oct 24, 2004 at 07:06 PM. Reason: Finished install, no more assistance needed.
Old Oct 15, 2004 | 11:31 PM
924runner's Avatar
my cb is mounted to the floor on the pass side trans hump(was there when i bought it so i left it).the antenna is on the left front fender(check link in sig)
Old Oct 15, 2004 | 11:33 PM
924runner's Avatar
sorry its here
http://bc4x4.com/album/steve-micaelo.jpg
Old Oct 16, 2004 | 04:24 AM
shovelhead's Avatar
If you don't smoke take out the ashtray, thats where I put one in my Taco
Old Oct 16, 2004 | 11:11 AM
4RunnerKid's Avatar
Yeah, that's where I would like to put it. I just wasn't sure if it would fit or not. I'll have to go measure it today.
Old Oct 16, 2004 | 12:28 PM
trd90toyota's Avatar
It should fit. You might have to cut the back off where the ash tray sits. it will look real clean.
Old Oct 16, 2004 | 12:54 PM
evilcow's Avatar
Old Oct 16, 2004 | 03:34 PM
Newdad's Avatar
I did the ashtray thing. You will have to cut out the plastic at the back of the opening and you will probably need an elbow for the coax at the back of the CB. I used velcro to stick it in place but the sticky back lets go when it gets too hot.
Picture of the elbow.
-Michael
Old Oct 16, 2004 | 11:34 PM
4RunnerKid's Avatar
-Michael
That's where I'm gonna try and mount mine too. How wide is your CB? Also, how did you go about mounting the antenna? Thanks!
Old Oct 22, 2004 | 10:36 AM
Newdad's Avatar
I don't know the measurement but my CB (cobra) is exactly the same width as the opening. It's a tight fit. I ran the coax through a hole in the firewall just above the gas pedal. I don't know what the hole is for, it just had a plastic plug in it. I cut an X opening in it and ran the coax through. So don't solder the end on until you've run the cable. My antenna is mounted on a ARB bracket on my bull bar. Also, I got the elbow from Radio Shack. Good luck.
-Michael
Old Oct 24, 2004 | 01:43 AM
4RunnerKid's Avatar
The CB is installed. Thanks for all your help guys. Now I just need to wait for my antenna to get here so I can finish the install...
Old Oct 25, 2004 | 12:39 AM
4RunnerKid's Avatar
pic...
Here's a pic of the install. I'll post pics of the antenna install once it's done.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
