GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
lowrance h20/ laptop
Old 02-22-2009, 11:22 AM
y2kltdsport's Avatar
Searched quite a bit didn't see any specific "up to date " info so here goes....What is necessary to make my lowrance h20 operate through my laptop?? ie. using my laptop as a monitor for the g.p.s. if that makes any sense??? thanks for any input whatsoever
Old 02-23-2009, 09:52 AM
jpmountainboy's Avatar
I am also interested.
Old 02-23-2009, 07:22 PM
Adam F's Avatar
Should work. I used to use a cheap Garmin handheld unit hooked to the serial port of a laptop and ran Copilot GPS software and it worked just fine.
Set your receiver to output "NMEA" and use this data cable
http://www.amazon.com/Lowrance-Cable.../dp/B0009J4I00
And use your gps enabled navigation software of choice.
Old 02-23-2009, 07:29 PM
Adam F's Avatar
Here's a free GPS program
http://www.easygps.com/gps_receivers...Finder_H20.asp
BTW I found all this using google in about 5 minutes
Old 02-23-2009, 09:07 PM
[QUOTE=Adam
BTW I found all this using google in about 5 minutes[/QUOTE]
Thanks alot,that makes me feel real"special" seriously, I appreciate it and will look into the info Thanks Adam
Old 02-23-2009, 09:23 PM
Hey Adam,
Is this the same type of cable ie. will it accomplish the same thing??http://www.pc-mobile.net/usgm.htm
cause it's a lot cheaper
Thanks Mike
Blamalam
03-12-2022 07:34 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
LittleUgly
15
01-02-2020 01:30 PM
digdug40
08-28-2015 02:24 PM
Quick Reply: lowrance h20/ laptop
