lowrance h20/ laptop
Searched quite a bit didn't see any specific "up to date " info so here goes....What is necessary to make my lowrance h20 operate through my laptop?? ie. using my laptop as a monitor for the g.p.s. if that makes any sense??? thanks for any input whatsoever
I am also interested.
Should work. I used to use a cheap Garmin handheld unit hooked to the serial port of a laptop and ran Copilot GPS software and it worked just fine.
Set your receiver to output "NMEA" and use this data cable http://www.amazon.com/Lowrance-Cable.../dp/B0009J4I00 And use your gps enabled navigation software of choice. |
Here's a free GPS program
http://www.easygps.com/gps_receivers...Finder_H20.asp BTW I found all this using google in about 5 minutes |
[QUOTE=Adam
BTW I found all this using google in about 5 minutes[/QUOTE] Thanks alot,that makes me feel real"special" seriously, I appreciate it and will look into the info Thanks Adam |
Hey Adam,
Is this the same type of cable ie. will it accomplish the same thing??http://www.pc-mobile.net/usgm.htm cause it's a lot cheaper Thanks Mike |
