GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Firestiks Fire Ring antenna lead
Old May 21, 2006 | 08:06 AM
Corey's Avatar
Co-Founder/Administrator
Who here has used the Firestik coax with the Fire Ring at the end?
http://firestik.com/Catalog/K-8R18.htm
I am use to old school where you have two wires at the end.
One for the antenna, the other for the ground.
Can you get a good ground this way, and if so, how?
Is it utilizing the antenna base for a ground instead?
I am rounding up new CB components for the installation in the future FJ Cruiser.
It will be interesting also where I end up putting a mount for the antenna since the FJC can not take a standard hood mount.
May mount it back by the spare tire until I put on an ARB bumper in the future.
Old May 21, 2006 | 08:11 AM
Localmotion's Avatar
I have the ring around mine, I just used it in conjunction with the firestik mount(same one bob had on his write up)
I Didnt worry about grounding or anything. It works great.
Old May 21, 2006 | 08:22 AM
Marc P's Avatar
I run the same setup--no problems. I got the mount and coax as a package deal on ebay.
Old May 21, 2006 | 08:23 AM
Corey's Avatar
Thanks Matt, found the article.
https://www.yotatech.com/forums/f127/rear-mounted-firestik-ii-antenna-3rd-gen-4runner-75291/
Looks like the Fire Ring grounds itself from the antenna base then.
Will have to get the mount as my very last item of components I am rounding up, as I do not know yet what will work with the FJC.
Many have not installed a CB yet into this rig.
Thanks Mark, looks good back there.
Old May 21, 2006 | 09:10 AM
waskillywabbit's Avatar
I got that cable Corey, works great, no problems. Now to just get my antenna/CB "tuned" properly so my reception/broadcasting is more than a mile or two.
Old May 21, 2006 | 06:34 PM
4x4Lamm's Avatar
Check my build-up thread, there is some info on them and some pics.
Lamm
Old Jun 12, 2006 | 02:03 PM
fourwd1's Avatar
Ham radio antenna cables have been using that sort of thing for years.
Obmi
Oct 30, 2015 04:27 PM
mulewright
Oct 3, 2015 02:47 PM
tazman1972
11
Sep 28, 2015 10:32 PM
themightykhoner
Sep 18, 2015 02:28 AM
Ilovemountains
Sep 15, 2015 04:17 AM
