GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB's and antennas
Old Nov 25, 2004 | 04:30 PM
Brew's Avatar
CB's and antennas
Hey again fellas,
Before I make my trip to Ouray and the surroundings, Im gonna purchase a CB radio. Im definitely no expert on CB radios, besides the fact that people seem to like "Cobra" brand.
Im looking to spend less than $100 on one, plus I need an antenna too.
All in all, Id appreciate your advice on what kind of CB radio and model to get, along with a good antenna...and are detachable antennas a good thing to buy? Id prefer not to have it on 24/7 if I dont have to...but I can cope if need be.
Thanks fellas ,
Brewsky
Old Nov 25, 2004 | 04:49 PM
CAM 1's Avatar
Thumbs up
Originally Posted by Brew
Hey again fellas,
Thanks fellas ,
Brewsky
You can always do this setup. Hand held CB with a magnetic base Antenna. Radioshack has a real nice hand held CB for $98.00. It is rechargable (nicad Batt) or can be used with the included cig lighter power cord. Then pickup a magnetic base antenna, (also radioshack) hook it to the antenna mount on the handheld CB and your all set. No cutting, mounting, grinding, quick and easy.
Craig.
Old Nov 25, 2004 | 05:59 PM
Brew's Avatar
I hear handheld CB's dont have a good range...about 4 miles is what Ive seen...would the magnetic antenna help a lot?
What is the usual range on a mounted, or non-handheld CB radio? Im just trying to keep my options open...either way Ill probably use a magnetic antenna.
Thanks,
Brewsky
Old Nov 25, 2004 | 06:16 PM
CAM 1's Avatar
Thanks,
Brewsky
Any hand held CB has the same (FCC Reg. output,range) as any fullsize "Hard install" CB (unless modified). The key to it IS the magnetic mount antenna connected to the handheld CB. The higher up on the rig the better. The setup I have is a handheld (midland) CB connected to a magnetic mount antenna (on the roof) when needed. This is a quick and simple way to run a CB with decent range for any road trip. (ie) Hear trucker reports on traffic, backups, Cops running radar,etc.
Craig.
Old Nov 25, 2004 | 06:54 PM
Brew's Avatar
Thanks fellas
Im probably gonna go with the handheld/magnetic setup then...
Thanks again,
Brewsky
Old Nov 25, 2004 | 07:14 PM
AzStorm's Avatar
Cobra radios used to be the way to go.These days the Uniden is the one to have.It uses the same board the older Cobras used.Strong TX and an excellent receive circuit.
Id reconsider the handheld unit.They just dont do the job a mobile set up will and are designed more for roadside emergency use.
Uniden has some great rebates going right now that make their units even more attractive.
If it were me? Id go with a simple Uniden,PC 68 or 78XL depending on the features youre looking for and a wilson 1000 magnetic roof mount.
The wilson antennas have excellent receive capabillities and are extreemly durable.Moreso than the Firestick antennas everyone seems to go with and the transmit and receive far better than any fiberglass set up Ive ever seen.
Hope this helps
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
shisha1999
Sep 20, 2015 11:35 AM
Ilovemountains
Sep 15, 2015 04:17 AM
msged2007
Aug 22, 2015 07:46 PM
