CB Static
From: Houston (home), Atlanta (school), Cincinnati (work)
CB Static
I have a general question....I know that proper grounds and power are required for a CB to get optimal reception and clarity along with a good, tuned antenna. However, in general, if you flip on your CB and tune to a channel with no activity, should it be dead quiet or full of static? How about when you flip to a channel being used (such as 19 on the highway)? Should there be static behind the voice? Clear behind the voice? Static between transmissions? I'm wondering if mine needs to be cleaned up or not. Thanks!
staic in the backgound would be normal depending on squelch setting.
static on recive is relitive. it either means your setup is sketch, or the person transmitting is sketchy.
a properly convfigured system on both ends, you should hear a clear clean crisp voice. or known as full quieting.
KC0TXH
KC0TXH
my squelch is all the way down (turned to the left). there is a very small band at the low end where I can hear the static, once I pass a certain point, the static goes away but so do the voices i think, though i should test this again...
Fell free to
me if I'm totally wrong
Erich
thanks guys, i forgot to update. i caravaned with some friend for about an hour drive and they each had handheld CBs so we were able to speack just fine. i turned my squelch until the static went away and then all i heard was them when broadcasting. thanks again
CB frequency is 27 MHz, prone to manmade and natural noise. Add to that the noise from millions of CBers worldwide keying up, and you always have some level of static/noise. It's usually lower at night, because the atmospheric effects that increase it are gone at night.
theking11863
Mar 19, 2016 09:36 PM
CanRunner
Jul 20, 2015 01:29 PM
drguitarum2005
Sep 3, 2006 10:15 PM
