GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB Install Help
Old Apr 12, 2007 | 04:43 PM
CJM's Avatar
CJM
Post CB Install Help
Just nabbed a cobra 19 ultra III at wally world, and I wanted to install it in my 96 T100.
I dont wanna run it from the battery, I want to tap the cig lighter for power..I dont ever use it so I think its good and less complicate and I dont have to worry about my wires melting from the heat of the engine.
Now bear with me, but I take a voltmeter (multimeter,whatever) and check the wires till I find one thats hot and tap that. Then of course I ground the black to the sheetmetal that is all behind my dash..
I mean I can wire stuff, but usually houses are different than cars...
Thanks
Old Apr 12, 2007 | 09:25 PM
Merlin's Avatar
You could save yourself some time and trouble and tap the hot wire from the fuse block under the dash (hot when ignition is on, so you don't leave your radio on overnight) and then ground to bolt under dash.
If you don't want to do that, what my friend did is take apart the center console, remove cigarette lighter plug housing, and tap power and ground wires from that. Then reinstall plug housing, and you get a factory-looking clean install. He doesn't smoke, so no need to worry about overloading the circuit by actually using the plug as a lighter.
Old Apr 12, 2007 | 09:37 PM
91TPU's Avatar
i thinking about the same thing, running power off the cig lighter, figure ground it to some clean metal, then run the hot to the cb...should be that simple, mine wont be any high tech model
Old Apr 13, 2007 | 02:59 AM
CJM's Avatar
CJM
Well, I think the hot from the fuse block could work. Which wire is that even, I would need a wiring diagram right?
So I could overload the cigg lighter tho, say if I plugged in my phone charger?
Old Apr 13, 2007 | 03:24 AM
NaeSLaS's Avatar
Or, just get a cigarette lighter adapter, cut and splice the wires, and plug your CB into the cigarette lighter when you need it (like i do).
Old Apr 13, 2007 | 03:53 AM
CJM's Avatar
CJM
Nah, that makes it look ugly as its all exposed, a good idea if II cant do anything else tho. THanks.
Old Apr 13, 2007 | 04:35 AM
Pest's Avatar
My CB is tapped into both the hot and ground wires running from my cig lighter. I use the lighter to charge my little jumper pack/air pump. Hasn't blown a fuse yet.
Old Apr 13, 2007 | 04:47 AM
NaeSLaS's Avatar
true enough...but then again, i switch my CB from car to car.
magnetized antennas don't get very good reception.
Old Apr 13, 2007 | 10:40 AM
surf4runner's Avatar
i like my K-40 w/mag mount. good reception too.
CB powered through the cig lighter.
simple to move to another vehicle.
Old Apr 13, 2007 | 05:33 PM
CJM's Avatar
CJM
Well, I finally gave up trying to fab up a mount so I didnt have to remove anything. The T100 lower console area just doesnt work right b/c of where the radio, ashtray and cigg lighter are. So I ripped out the ashtray since I dont use it except to hold junk and with some minor trimming my cb will fit..
Old Apr 30, 2007 | 06:34 AM
toy4wd's Avatar
if you tap the cigarette lighter your going to get whine use one of these
http://www.jcwhitney.com/autoparts/S...1&sku=mh037093
Old May 1, 2007 | 04:41 AM
Mark in MD's Avatar
Here's what I have, nothing to install because everything is in the hand held unit:
I have magnetic antenna. I only use mine on trips. It works nicely, range is around 2-3 miles.
You can also use it as a walkie-talkie (disconnect bottom part, add battery pack, antenna screws in), in case you get stuck in a valley or something and need to hike out on foot.
Old May 1, 2007 | 07:24 PM
CJM's Avatar
CJM
Update:
I installed it in the ashtray as planned, fit pretty well too. I originally just plugged the wire into the cig lighter plug for power but got noise whenever i had the squelch turned up. Also my lighter didnt work and my phone charger is handy.
So I took a simple plug and made it fit my cig lighter, then spliced two wires to it and made one with aplug for the lighter and the other for the CB. No electronic noise and it works great..now I need to run an antenna.
Old May 4, 2007 | 09:48 AM
89silverpu's Avatar
pictures?
Old May 4, 2007 | 10:55 AM
91TPU's Avatar
yea show me some pictures of what you did with the wiring to the cig lighter marc!
Old May 13, 2007 | 11:57 AM
deserttoy84's Avatar
wiring to the battery takes under 30 minutes. LAZZZZZZZY
Old May 15, 2007 | 12:02 AM
CJM's Avatar
CJM
More like I didnt wanna run the wiring through the firewall..
Old May 15, 2007 | 08:35 AM
there are so many plugs you can route the wires through on toyotas. you just gotta find them.
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
