GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB antenna quick disconnect and spring question
Old Oct 20, 2005 | 04:23 AM
shotking4's Avatar
I ordered my Firestik II and Firestick door jamb mount and spring from walcott CB the other day. when i ordered it, i asked about a quick disconnect and the guy said he didn't recommend it paired with a spring. I didn't ask any more and he didn't elaborate on it. I was thinking last nite as i mounted the mount in my rear hatch that i wanted a quick disconnect. I don't see why it would be a bad idea to mount the spring, then the quick disconnect and then the antenna. The disconnect wouldn't have the stress of the spring on it if i mount it about the spring, would it? Any thoughts are appreciated. thanks in advance.
Old Oct 20, 2005 | 04:44 AM
Marc P's Avatar
I have the setup you are describing. The first time out the pin that holds the disco together fell out and I almost lost the antenna. I am not sure if this was caused by the spring.
I fixed it by drilling a hole through the disco and now I use a small bolt and wingnut.
Old Oct 20, 2005 | 05:24 AM
shotking4's Avatar
thanks Marc. I decided to bail on it. i was talking to some ne4roc guys and they said i didn't need it. I just wanted it so i could get into my trunk, but they said the antenna doesn't have to be removed to get in there.
Old Oct 22, 2005 | 02:48 AM
jimbo74's Avatar
this is a cocuple days old... but my old explroer had a quick release above the spring mounted to my roof rack cross bar... never had any problems with it liek that, and i never had any breakage issues... sometimes the antenna would hit things and lay flat and the quick release and the spring were always fine
Old Oct 22, 2005 | 03:19 AM
Intrepid's Avatar
But were you wheeling that truck? I know my antenna takes some serious abuse off road, I figure, even without the disconnect you can get it off pretty quickly with a wrench. Better safe than sorry.
Old Oct 22, 2005 | 03:23 AM
jimbo74's Avatar
yes i did wheel it....i laid the antenna down a lot, made scary noise inside the truck..... but never broke off or had any problem... i was actually worried that it woudl rip my crossbar off and it never did....
coffey50
Jul 28, 2015 10:55 AM
boogiewoogie
Jul 24, 2015 05:10 AM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
