Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
what needs to be removed for 1993 pickup cd install?
Old Aug 20, 2005 | 03:46 PM
brendonv's Avatar
Im planning on putting in my cd player in my 1993 pickup tommorrow, what needs to be removed to get at the stereo for proper installation? is there any secret bolts or anything i should be aware of before i start?
Old Aug 20, 2005 | 04:40 PM
Silver_Truck's Avatar
gotta take off the lower dash on drivers side, glove box, centre piece, you gotta pop off the climate control panel to get the the screw underneath it...other then that I don't remember anything really hidden. Good luck!
Old Aug 20, 2005 | 06:25 PM
94x4's Avatar
Guest
Other than what Silver_Truck's told you, you should type "Stereo install" in the Search window to get alot of information about what you're up to.
Old Aug 23, 2005 | 10:20 AM
Brendan's Avatar
there's a website that shows you step by step instructions on how to install a head unit in almost any vehicle, but of course i can't find itt right now. it's really simple though.
Old Aug 23, 2005 | 11:09 AM
JEDI87's Avatar
Like said above,you have the lower dash panel under the steering wheel,trim piece around the ignition,heater control panel(snaps in and out),glove box(open it to get to the screws on the left hand side),and then the center trim panel.After you get those pieces out you have to take the 4 screws that hold the stereo/cubby out,then you have to unscrew the cubby from the stock stereo and mount it to the new deck.Make sure you buy the wiring harness for like 20-30 bucks.It will just plug into the trucks harness and make things sooooo much easier.http://www.cardomain.com/item/SCOTA02B
Old Aug 23, 2005 | 12:56 PM
Astralplane's Avatar
Here it is:
http://www.installdr.com/InstallDocs...PDF/869017.pdf
On a side note,you can hook up the dimmer wire (orange).
Old Aug 23, 2005 | 06:44 PM
Brendan's Avatar
Bingo!
Old Aug 23, 2005 | 08:42 PM
arjan's Avatar
Interesting, handy link.
Old Aug 26, 2005 | 01:38 PM
bryanr's Avatar
Originally Posted by Astralplane
Here it is:
Excellent link! Thank you sir
Old Oct 28, 2005 | 06:44 PM
Etype R's Avatar
Another thanks! I just picked up a new deck tonight and plan to install it tomarrow. So I started skimming over the threads in here hoping for some times. This is way more then I expected to find and will be very helpful.
Weidle
Jan 21, 2019 05:39 AM
Colington
Oct 12, 2015 05:41 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Valvoman
Jun 28, 2015 02:45 PM
Iceman4193
Jun 28, 2015 10:30 AM
