Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Unhooking an amp + capacitor
Old Sep 14, 2004 | 08:36 AM
phoenix808's Avatar
Unhappy Unhooking an amp + capacitor
So I'm "going in" for round 2 of sound deadening (this episode: floors and roofliner) and need to take out my system.
Problem is, I was a wuss and had the amps/cap installed for me instead of doing it myself. So i have no idea if unhooking the capacitor from the amps is dangerous...
Obviously, disconnecting the bat is the first step...then what? do i have to drain the capacitor?
Old Sep 14, 2004 | 08:50 AM
Ehinfinity's Avatar
Yes the cap needs to be drained, it can be done without but depending on the amount of joules, it can cause a nasty shock.
Old Sep 14, 2004 | 09:36 AM
COYOTA $x$'s Avatar
You know how you test 9volt batteries by putting it on your tongue ?
You DONT want to do that with the Cap.
Old Sep 14, 2004 | 09:38 AM
96LtdYota's Avatar
what would happen, other than loss of bodily functions.
Old Sep 14, 2004 | 11:29 AM
Ehinfinity's Avatar
Well it depends on home many joules the cap is,it won't be enought to kill you but i dont want to try it out. The more joules=more stored power= more pain.
Old Sep 14, 2004 | 12:25 PM
dbikeman's Avatar
lol I have a batcap800 to tend with 2. If i did that between my cap and that battery I think I could get fried.
Old Sep 14, 2004 | 01:33 PM
phoenix808's Avatar
any tips on how to drain/recharge one? obviously i'll google it, but i always prefer a fellow yotatecher's opinion....
Old Sep 14, 2004 | 02:32 PM
Ehinfinity's Avatar
I have two Monster 1.0 caps, bought one new other used. Their was a little circuit board that came with the new one for powering up and draning it. If i had two I will send you one. Ill check when I get home to see if I might have two.
Eric
Old Sep 14, 2004 | 02:43 PM
phoenix808's Avatar
Eric
wow. thanks! just let me know...
Old Sep 14, 2004 | 05:38 PM
95_4X4Runner's Avatar
Couldn't you just hook up a regular 12V auto light bulb to it? You'd get a "visual for when it was fully discharged.
They can be dangerous, the one I have was from the military, only .8 farad, but free. The first time I just hooked it up in parallel with the amp power, and when I plugged the fuse in, it blew a 35 amp right in my fingers. So, I now use a couple 4 ohm sand-filled resistors in series to charge it up before the fuse, and it has worked fine.
beltcutter
Sep 30, 2015 06:14 AM
toyotasaurus
Sep 24, 2015 03:30 PM
sonorn67
Sep 19, 2015 05:39 PM
potatopants
Sep 15, 2015 06:26 AM
toyotafreak98
Sep 10, 2015 02:57 PM
